Coolant Drain
Old Aug 9, 2008 | 12:32 PM
LandsEnd's Avatar
Coolant Drain
Do you have to remove the plastic cover under the car to get to the drain plug on the radiator? Time to change the coolant.
Old Aug 9, 2008 | 12:44 PM
Hilbe's Avatar
What do you guys do with your coolant? I need to find a place to take mine when I change it.
Old Aug 9, 2008 | 12:48 PM
!PrjctMax!'s Avatar
I just had my tech do it at NISSAN. There was a machine that sucked all of it out and put brand new neon green fluid in
Hilbe-just take it to a dealer or Jiffy Lube or something and I've heard that the local spots have to dispose of it for you.
Old Aug 9, 2008 | 02:19 PM
WINTERFAUST's Avatar
Its not too expensive to just have the dealer do it. Also be careful our cooling system is pretty much a pain in the *** to bleed. We get alot of people come in that try to do it themselves and get air pockets in the heater core.
Old Aug 9, 2008 | 10:18 PM
LandsEnd's Avatar
Do you have to remove the plastic cover under the car to get to the drain plug on the radiator? I'm only draining the fluid out of the radiator, and reservoir area which will get most of it so there won't be any air in the system to bleed correct?
Old Aug 10, 2008 | 04:50 PM
Torchcorvette's Avatar
How soon should the anti freeze be drained and replaced???
Miket2006
Mar 1, 2021 03:55 AM
Forge277
Jun 13, 2016 09:26 PM
foodmanry
Sep 24, 2015 12:02 PM
97_GXE
20
Sep 17, 2015 08:12 PM
markevans999
Sep 10, 2015 04:29 PM
