TPMS season has arrived.....again
Old Oct 5, 2008 | 12:54 PM
reb's Avatar
reb
Outside temp dropped into the 40's the other day. Upon start-up in AM TPMS light engaged. Checked cold tire pressure, 32 lbs all around. Inflated all 4 tires to 36lbs. Been driving around for 3 day now, stupid or should I say, IDIOT light is still on.
What a useless, poorly engineered system.........
Old Oct 5, 2008 | 01:42 PM
jetsfan2008's Avatar
TPMS light? i take it this is frequent when it gets cold?
Old Oct 5, 2008 | 04:32 PM
KCMAXX's Avatar
KC's FINEST
You may have a sensor in the spare as well.
My max didn't come with TPMS but my Pathfinder did.
Old Oct 5, 2008 | 04:54 PM
!PrjctMax!'s Avatar
Pull all of the sensors from the wheels and pull the fuse the system and you're set
Old Oct 5, 2008 | 08:35 PM
DAlastDON's Avatar
Mine is on too. I checked the pressure and i have 31psi all the way around. But i have been too lazy to unroll the air hose in the garage. I usually only drive the car once a week so I'm not sweating it.
Its nice to have a company vehicle.
Old Oct 5, 2008 | 08:42 PM
STARR's Avatar
Guess we can all thank Ford and Firestone for this
Old Oct 6, 2008 | 08:06 AM
mynameispee's Avatar
its possible that you need to recalibrate all four sensors or have a faulty sensor(s). take it to the dealership, only takes a few minutes to recalibrate/diagnose.
Old Oct 6, 2008 | 09:31 AM
novabortion's Avatar
should i get used to this? This morning my tpms light came on (for the first time) and tires looked fine but only checked two of them and they had 31psi. Today was one of the first cold mornings for cali. So i put in about 38psi and eventually the light came off about 10mins later. So im assuming i should be seeing the light more often in cold weather?
Old Oct 6, 2008 | 09:24 PM
I VIK I's Avatar
38 is way to much in my opinoin depending on tire most people tend to keep it at 32 psi cold. as the tire rotates the air heats therefore expands and you have a greater internal pressure on the highways.
Old Oct 7, 2008 | 08:19 AM
thanks, thats good to know. I thought my tires were losing air so i thought extra air wouldnt hurt. Time to let some air out. thanks.
Old Oct 7, 2008 | 12:28 PM
reb's Avatar
reb
My system was calibrated last winter, been there done that.
Apparently, to get the TMPS light to go off, one has to over-inflate the tires.
After filling mine up to 37psi cold tire pressure, the light went out after about 10 miles.
note, that my light was still on after I inflated them from 32 to 36. So on my car atleast, the trigger is set at 37psi.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Serotta33
Sep 17, 2015 12:14 PM
carid
Sep 17, 2015 05:00 AM
NissLover
Aug 22, 2015 10:26 AM
gizzsdad
Aug 19, 2015 01:01 PM
