Eibach Wheel Spacers
Old Oct 11, 2008 | 03:45 AM
coolmax05's Avatar
As some of you know, I recently bought 2009 Maxima 19" Sport Wheels.
The problem? HUGE +50mm offset! The good news? Gives me the option to go with a +25mm Eibach Spacer wich means I do not have to replace the factory studs. This part number comes with studs already attached to the spacer. This in-turn, utilizes the factory studs to attach the wheel spacer to the rotor.
The spacers have no vibration what-so-ever. They are hubcentric. Incindentally, 25mm is about a inch.
Old Oct 11, 2008 | 03:50 AM
coolmax05's Avatar
Here you'll see before then after shots of with and without the 1 inch spacer. let me tell you, it looks way nicer from the sides and the back. Now I have to wait for the two front wheell spacers to arrive. As you can see it fills the wheelwells better with the spacers.
Old Oct 11, 2008 | 03:58 AM
coolmax05's Avatar
Old Oct 11, 2008 | 04:05 AM
lebanondon61's Avatar
They look cool
Old Oct 11, 2008 | 05:11 AM
KCMAXX's Avatar
KC's FINEST
Good luck....
Old Oct 11, 2008 | 05:52 AM
NiZMo1o1's Avatar
looks good !
Old Oct 11, 2008 | 08:49 AM
BlackDUBS's Avatar
Thats a big difference. Looks much better.
Old Oct 11, 2008 | 09:13 AM
coolmax05's Avatar
Thanks guys. Those black dubs are sharp!
Here's a picture from the rear. Even with 245 tires the stance looks nice and wide. As you can see from the second picture I'm staggered big time. The fronts are still at a +50mm offset. I can't wait for the other spacers to come in for the fronts.
STAGGERED BIG TIME!
Old Oct 11, 2008 | 11:21 AM
Fastmax05's Avatar
"Ok,Whats next?!?!"
Good job man you are half way there ....
when do the others come in ?
Old Oct 11, 2008 | 01:23 PM
coolmax05's Avatar
Still trying to find someone who has them in stock. Hopefully I'll have them by next weekend. IN my opinion, with a 8 inch wheel +25mm offset is the perfect stance for most applications if you like your wheel flush. I am lowered .5 inches in the rear (Eibachs with a .3 inch rear spring spacer). So far no rubbing at all. My AGX shocks are set at 6 so they do have less bounce than OEM shocks. With GR2's this offset should not be a problem.
If you have a factory 18" wheel, then a 15mm spacer is as wide as you should go. I'm guessing that a 5mm spacer does not require you replace the studs. I think 5mm spacers would look great on your car fastmax. Even in just the rears to give you a staggered look. About $55 a pair.
Old Oct 11, 2008 | 01:46 PM
bizzee's Avatar
How much did the wheels cost?
Old Oct 11, 2008 | 02:53 PM
coolmax05's Avatar
Brand new wheels and tires off a 2009 Maxima for $1000.
Old Oct 11, 2008 | 04:45 PM
!PrjctMax!'s Avatar
5mm spacers do NOT require studs, but I believe some come with them anyway.
I had 15mm in the rear with the 350Z track wheels; 18x8 with a 30 offset and only one side rubbed, but the other was alright.
Old Oct 12, 2008 | 06:21 AM
orlan85's Avatar
Newbie
It looks good. A Big difference
Old Nov 1, 2009 | 03:49 AM
wcasskicker's Avatar
Hey coolMax, I also purchased Eibach for for my 5th gen Max few years back. I purchased 15mm for front and 25mm for the back. I'm having fitment issue with my aftermarket rim. See my story.
http://www.cardomain.com/ride/205163/7
http://forums.maxima.org/5th-generat...-included.html
Old Nov 1, 2009 | 10:29 AM
XxxSunNyxxX's Avatar
Mang that ish is nice! I need to get it. How much is this wheel spacer thing? I have 20" TSW Sennerton and I lowered it with Eibach pro-kit. The tires size are 245/35/20. It dosent rubb, but if I get the spacer to stick out and flush with my fender and 1/4 panel, will it rubb? Please help! Thanx
Old Nov 1, 2009 | 03:28 PM
chernmax's Avatar
Nations 1st 6th Gen Turbo
I have EiBach 5mm spacers all around but used the studs that came with them because of the quality and having new!
Old Apr 18, 2010 | 02:01 PM
lblackonblackl's Avatar
SHIFT_my stick
anyone got a link to where i can buy these? just bought 2010s... im slammed on coilovers and wouldnt mind 25mm tucked! if i do 25 in the rear what should i do in the front???
Old Apr 18, 2010 | 02:27 PM
xorbitman's Avatar
WOW, man that looks sick! How is it you only paid $1K?
My wheels are Konigs and the tires are 245/45/18 Riken Raptor ZR rated...(second line of Michelin) the wheels alone were $1k and the tires are $600. The CDN dollar is roughly par with the US now.
Old Apr 18, 2010 | 03:13 PM
SHIFT_my stick
i paid 1000 for mine too 2010s!!!
Old Apr 18, 2010 | 05:45 PM
PetitFrereMaxima's Avatar
I paid $1100 for my 2010s shipped from New York City to Houston.
Old Apr 19, 2010 | 09:03 AM
bigdogmacree's Avatar
fyi...not that i care but those rims are all hot... and by hot i dont mean they look good (even tho they do)
Old Sep 13, 2011 | 08:32 PM
Promise*Freedom's Avatar
Did you have any camber adjustment problems after the lowering kit and wheel spacers were installed?
Peter Paul
Jan 2, 2016 05:18 PM
Lowered_a33
Sep 10, 2015 09:41 PM
dcam0326
Sep 8, 2015 11:02 PM
Maxboy23
Sep 4, 2015 06:04 PM
