Uprev and Vista problems
Old Nov 2, 2008 | 11:22 PM
DeusExMaxima's Avatar
Anyone here have Uprev Cipher using Vista? I am having problems connecting to teh car using Vista on my new laptop. I re set compatibility to Windows XP and it still doesnt work
Old Nov 3, 2008 | 12:06 AM
Oolatec's Avatar
Probably just isn't compatible with Vista, even if you change the compatibility setting.
Old Nov 3, 2008 | 12:49 AM
I have heard of some people not having issues. May have something to do with settings. Saw that on Titan forum.
Old Nov 3, 2008 | 01:15 AM
po8pimp's Avatar
so a little off subject but what does Cipher do for you? I mean I read the uprev website but besides it being a obd2 reader and a data log what can you do with it. I was thinking about investing in that HPX MAF Sensor and Osiris Tuner. reading about the HPX Sensor it doesn't sound like it comes with any equipment for loading or adjustment of A/F ratio.
Old Nov 3, 2008 | 01:24 AM
po8pimp's Avatar
What versions of windows have been tested?
Windows 2000, XP, and Vista.
found this in the faqs page for UpRev. I would call them direct if you can't figure it out
Old Nov 3, 2008 | 06:15 AM
NiZMo1o1's Avatar
Dues ,alot of guys that are using piggyback standalones arent havent any luck with Vista, gotta downgrade, my buddy using a Kpro and a few others I know arent having any luck with it. I myself , also can tune my UTEC on Vista, I end up reformatting the laptop and downgrading
Old Nov 3, 2008 | 08:05 AM
The Cipher just plugs in to the ECU port below the steering wheel and monitors sensors and also allows for ajustment of idle and timing (+ or - 2 degrees), so its limited in what it can d. Its not like UTEC or Osiris, or any of the full functioning piggybacks. I use it to pull codes and to adjust timing and idle.
Old Nov 3, 2008 | 08:34 AM
NiZMo1o1's Avatar
why dont you Email UpRev then, the guy tries to push his product all over my350z
Old Nov 7, 2008 | 01:51 PM
NmexMAX's Avatar
dot dot dot ...
My UpRev works perfectly fine w/ Vista.
The guy doens't take to us Maximas too well, even though the A34 could probably easily use the OSIRUS.
Old Nov 7, 2008 | 06:42 PM
My Vista is a 64 bit OS. What is urs Nmex? Uprev only works on 32 bit operating systems.
Old Nov 7, 2008 | 11:58 PM
NmexMAX's Avatar
dot dot dot ...
Jesus, how does my **** tell my "Vista version" is?
Old Nov 8, 2008 | 05:33 AM
NiZMo1o1's Avatar
Control Panel / System
Old Nov 8, 2008 | 10:54 AM
NmexMAX's Avatar
dot dot dot ...
Strange thing is, my WB software doesn't like vista. The software runs fine, but it can never detect the USB connection. My 10 yr old laptop does just fine with it.
Old Nov 8, 2008 | 05:47 PM
NiZMo1o1's Avatar
Vista sux ***** , TurboXs Tunner and UTEC is never detected under Vista. I had to downgrade and reformat it to XP
Old Nov 8, 2008 | 08:59 PM
Mine isnt detecting the USB connection too!! Thats the problem.
Old Nov 8, 2008 | 09:40 PM
NmexMAX's Avatar
dot dot dot ...
Hmm, like I said, my UpRev is fine, but my PLX is a different story. BTW, how the heck are ya Dues?
Old Nov 8, 2008 | 09:56 PM
Doing good Nmex. Got single exhaust now. My TS dyno tune caused my idle to be rough and off idel throttle causes an engine miss. ANy ideas?
Old Mar 15, 2009 | 01:03 AM
bump
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
