Grinding noise
Old Nov 18, 2008 | 06:37 PM
6genmax's Avatar
Grinding noise
My '05 is making a grinding noise. The noise gets worse when I hit the brakes or bear to the left, but it will come and go even when driving straight. It goes away as I approach about 45 mph. It sounded like the break pads grinding, so I had them checked out, but the mechanic thinks its a bushing where the body is connected. Anyone run into this? Is it covered under warranty?
Thanks. Much Appreciated.
Old Nov 19, 2008 | 03:55 PM
Shoey1's Avatar
wheel bearing. if it goes away or gets worse under cornering im almost positive its a wheel bearing.
Old Nov 20, 2008 | 02:53 AM
ramberg's Avatar
GrandPa
What year and how many miles on the car? If its still under warranty take it to the dealership.
Old Nov 20, 2008 | 04:06 AM
nysmaxima's Avatar
same symptoms...had both rear wheel bearings replaced under warranty...left rear at 41,000 mi...right rear 51,000 mi
Old Nov 20, 2008 | 12:34 PM
MAX2DAMAX's Avatar
check your brake pads and your rotors for marks as well.
Old Nov 22, 2008 | 06:34 PM
6genmax's Avatar
Its an '05 with low miles, 27,200. I'm taking it in on Monday.....hope its still under warranty!
Old Nov 22, 2008 | 06:36 PM
6genmax's Avatar
Thanks NYS, the noise is definitely coming from the front, I wonder if it could be the same problem. I hope it is covered under warranty.
Old Nov 22, 2008 | 06:45 PM
PaulyFingaz's Avatar
anybody help me with a squeek i hear when i hit bumps coming from my drivers side wheel well.
Old May 7, 2009 | 06:40 PM
SaintRacing's Avatar
Noise heard when braking!!!
I have an 06 Max I just purchased with 54k miles. When applying the brakes to slow down I start to hear grinding from about 20 mph and til the car stops. Pads look good. Backs are a little worn. I can feel it in the pedal too.
Old May 27, 2009 | 09:17 PM
rehmankhan19's Avatar
I was having the same problem . I replaced my Hub Bearing Assembly. Everything was fine until last week. Noise came back again . I had it checked by one of my friend. HE said its the tire. My tire tread was uneven. Make sure u have someone check your tire's tread. Let me knw if its helpful
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
