Another A/C Thread Help!
Old Dec 3, 2008 | 10:04 AM
KC2010's Avatar
It's been fairly cold in Houston and I haven't had the need to run my a/c for about two weeks now. Well, today the temp got up to 80 and I just wanted to chill the car a bit. I turned on my a/c and the air isn't cold when set on 60 deg. It just blows room temp air.
It's 105 for diagnosis and then it's waived once the problem is found and I decide to have it fixed. I'd like to know from the max community what I should do on my own before going to the dealership.
1. Check freon pressure?
2. ??
3. ??
Also, I've searched the org already for threads regarding this. Not much there to go by so no hatin please. I'm just looking for advice from people who would like to help.
Thanks again guys!
Kevin
Old Dec 3, 2008 | 03:42 PM
redls1's Avatar
MAXIN' ON
Compresser cycling?
Old Dec 3, 2008 | 04:22 PM
Lovemycar's Avatar
You have a leak lower hose
Old Dec 3, 2008 | 04:43 PM
KC2010's Avatar
Thanks guys! So I should get a tracer kit or find someone who has one. Cool. Thanks again.
Kev
Old Dec 3, 2008 | 05:06 PM
hmr1979's Avatar
I have the same exact problem just this morning. Is the leak lower hose common? I am wondering how you knew this right away. I am going to check my freon level tomorrow I think someone in town checks it for free, but if its not freon problem, I'll know what else it could be, ty
Old Dec 3, 2008 | 08:36 PM
mynameispee's Avatar
yeah check the low side hose. i've replaced a handful of those on the 6th maximas including my own. to the left side of the radiator you'll probably notice a lot of debris and green color filament coating the low side a/c hose.
Old Dec 4, 2008 | 05:55 AM
KC2010's Avatar
I wonder if installing my FSTB might of had something to do with this. Not the actual FSTB but my installation.. Hmmm... I'll look at it this weekend. I bought a freon kit last night just in case.
Old Dec 4, 2008 | 09:34 AM
Torgus's Avatar
did you press the AC button?
j/k
Old Dec 4, 2008 | 10:31 AM
KC2010's Avatar
It's like when I'm doing PC tech work. Is the PC plugged into the wall? Yes? Next step....
HAHA!!
j/k
Old Dec 4, 2008 | 12:26 PM
MaxFan's Avatar
Same exact problem here. Just found out last week when changing oil. The leaking area is on the low-pressure A/C hose, right in-front of the oil dip-stick. I drove the car over the Thanksgiving weekend. I started to here the short grinding noise when turning on the A/C. Had it replaced at an independent shop ($137 for hose, $50 for freon, $50 labor). Somehow, the car feels much better now. No mistery sounds that I couldnot tell for so long. Please check that hose in your car. Don't risk running the compressor without any lubricant, for so long.
Old Dec 4, 2008 | 01:16 PM
KC2010's Avatar
I hear a mysterious sound too. Like an airy empty tin can sound sorta. I'll just leave the a/c off until I can get to a cheap mechanic like yours.
Old Dec 4, 2008 | 07:27 PM
chris350's Avatar
i think I have the same problem currently....no freon...there is a leak somewhere...would the warranty cover this? i have a 2006 max with 26k miles..or am i just gonna have to come out of pocket for this.?
Old Dec 4, 2008 | 09:13 PM
it'll be covered under warranty. 3months/36k miles.
Old Dec 5, 2008 | 06:00 AM
KC2010's Avatar
I checked the psi last night and it was 5 psi w/ ambient temp of 60 degrees. I added freon and now the A/C is blowing ice cold and the compressor finally kicked on. My mechanic will check the psi this weekend and look for any type of leak.
Old Jan 12, 2009 | 09:39 PM
cubbyjg's Avatar
I also live in houston and have noticed when i put my AC on around 73, its blowing hot air. Only when i put it down in the 60's do i get cool air. Is there a way to check the freon level? I dont hear anything unusual so i figured it must be this. Any other ideas?
Old Jan 13, 2009 | 05:49 AM
KC2010's Avatar
Autozone has some kits for $24 that reads very accurately your low end PSI. Some cans of freon come with gauges. Make sure you find one with the actual psi reading and not just a color gauge. After I get my bumper installed I'll be installing my low end hose. I think I'll do a I write up with pics for other orgers down the road.
Old Jan 13, 2009 | 03:53 PM
6thGenSmoke's Avatar
i had to add freon as well and its working good right now. isn't it kind of early for our cars to be low on freon though? mine is an 05 and i thought it was weird that it was lacking only after 3 years
Old Jan 13, 2009 | 05:45 PM
cubbyjg's Avatar
well I have an appointment at the dealership this Thursday. Should be under warranty since i bought it less than a year ago, its a certified Nissan and under 36k miles. If they say i have to pay for something, im going to be fing pissed.
Old Jan 14, 2009 | 04:30 AM
ramberg's Avatar
GrandPa
I have the same problem with the grinding when I press auto. I am going to have it checked out. I thought is was the compresser. Thanks for posting this.
Old Jan 14, 2009 | 05:57 PM
Talon05's Avatar
Just wanted to chime in. I live in Florida and I had my lower hose replaced at a small auto shop for 243.00 the dealership wanted 420.00. The hose actually cost 125.00 the rest is labor for evacuating and recharing the system. I would say bypass the dealer and get a few qoutes and make the shops compete against each other for the best price. The air blows artic cold.
Oh Yeah dont let a shop tell you that they can fix the hose by cutting it and repair it. Also have them do a pressure test before they do the work, because one shop told me that both hoses were bad, when in fact the low pressure hose was the culprit. GOOD LUCK.
Old Jan 15, 2009 | 03:05 PM
so after adding the freon my ac is no longer cold..it lasted about a week. how hard is it to do yourself?
Old Feb 26, 2009 | 12:53 PM
sparky1562's Avatar
My 2008 AC is not working either. I don't see any signs of leaking at the hose in front of the oil dip stick, but there is some green looking material at the connection just after the shrader valve. I am assuming that I have the same problem with a leak at that point?
There is no pressure in the system!
Old Feb 26, 2009 | 05:19 PM
Lovemycar's Avatar
Dam Nissan still using those faulty hoses on the 08 aswell i'm so sick of there sick
Old Feb 26, 2009 | 05:37 PM
JoeyAces07's Avatar
My 07 had the same. Lower hose. Warranty though!!
Old Feb 26, 2009 | 07:26 PM
maximusprime's Avatar
Mine just makes a weird grinding noise when i turn it on...but it works
Old Feb 28, 2009 | 08:44 AM
Domestic Violence's Avatar
This Space for Rent
i have the same problem.... there are a variety of things that could be wrong (sensors, switches, hoses, compressor, evaporator)- and one thing to keep in mind is that the A/C system is sealed. it should never need 'charging'. if the refrigerant level is low, there is a leak.
my compressor doesnt cycle and i too get that 'hollow air' sound. lucky for me that its winter here in Philly and i dont 'need' the A/C, yet. its just a matter of finding the time to grab a case of beer, a low side hose (probably) and head to my buddys shop to have him fix it....
come to think of it, its really nice having a good friend with a fully-equipped 4 bay shop
Old Feb 28, 2009 | 11:14 AM
lobewiper's Avatar
To those doit-yourselfers who are adding freon to their systems: If you don't fix the leak first, you are wasting your time. I have a 96 Escort that still cools great and has never had any type of AC servicing. If you need to add freon, you have a leak!!!
Old Mar 2, 2009 | 07:47 AM
sparky1562's Avatar
Dealer just finished replaceing the darn hose.
Old Mar 2, 2009 | 12:33 PM
KC2010's Avatar
my best friend installed the new low end hose this weekend - $113 in parts
evac - free cause he owns the system
freon and loob - $20
Beer - $24
A/C is fixed
Old May 4, 2009 | 01:31 AM
barbear1978's Avatar
Damn I remember when I had friends in the biz... Beer and pizza, must be nice.
However, I'm in Germany now and have to pay US dealer parts prices, ask if they'll ship over here (no Maxima model in Europe), then have a European Nissan dealer to charge me out the @$$ for labor. In case you didn't know, the dollar-to-euro exchange rate sucks.
Do heed the advice about running your A/C with a leaky hose. You'll kill your compressor quick. I replaced mine thinking that was the problem, but it was just a symptom (it actually did go bad though, due to 'the leak'). Sounded like a whining, dying cat in my engine bay, especially when accellerating and running A/C.
Think I'm going to replace both high and low hoses just to be safe, and not get charged labor twice in case the low doesn't fix it. Damn I should've gotten this fixed under warranty before I left...
'05 SE, about to break the century mark... I blame my wife.
Old May 4, 2009 | 09:16 AM
Apollos2's Avatar
Yeah I'm on my 3rd A/C hose....
Old May 4, 2009 | 05:10 PM
chris350's Avatar
got mine changed at the dealer...under warranty....thankfully..
Old May 4, 2009 | 10:01 PM
xorbitman's Avatar
Wow, i can't believe how many of my fellow orgers have this same problem! Today I tried my AC and I found out that I have the same problem as everyone here! Phew! Makes your head spin! I will have to check if my extended warranty covers this...on top of that my engine is doing the "Check Engine Light" thingy! (Probably emission system). That I know is covered under my warranty.
So that low end hose, Eh?! I went to Crappy Tire (Canadian Tire) and they want much less than the stealership...however they want $90 for the dagnostic and $30 to replenish...then there is the price of that hose and the hourly rate that goes with it....Hey KC2010 where did you get the hose for sooo cheap?
I'm begining to smell hosing here....as being taken advantage of...hmm need to negotiate!
Old May 4, 2009 | 10:56 PM
BLACKNESS MONSTA's Avatar
How much did Canadian Tire want? I have same problem
Old May 5, 2009 | 02:00 AM
VANGtastic97's Avatar
My gf's 6th gen's A/C stoppped working recently, and I've been hearing this sound like water draining from one end of a hose to another. (from behind the dash) Could the sound and A/C be related?
And how hard is it to replace the lower hose? My buddy has a shop with the machine so labor really isn't a problem.
Old May 5, 2009 | 03:59 AM
Solow1's Avatar
same problem here... ima prolly go to nissan tomorrow and get that part, prolly install it myself
i havnt had my ac for a while now lol... and that freon gets crazy expensive!!
Old May 12, 2009 | 01:05 PM
xorbitman's Avatar
Crappy Tire wanted $100.00 for diagnostic plus $30 for bottle and and what ever the defective part cost to replace....assuming aftermarket low pressure hose...$30 + Labout...should be under 2 bills.
Found out my problem was also the low pressure hose....problem fixed at no cost under extended warranty!
Phew!
$0.00
Old May 13, 2009 | 09:14 AM
KC2010's Avatar
Water sound, I think, is related to the radiator. I've read a few thread on that.
It took my best friend, who happen to have an evac system about less than 10 minutes for the swap out of the leaking low end hose (could be off on time estimate) and the evac was about another 20 minutes. Then start car, put a/c on highest setting (w lowest temp) and charge it with a good gauge and lube/freon. Be sure to know what temp it is outside. It affects the psi readings. You friend with the shop will know all of this. Get the part, go to friends shop and say "Hey man, do your thang!" and chill.
Old May 13, 2009 | 11:09 PM
Ahh, I should have searched myself...I'm pretty sure I've got air in the lines. Thanks for the help!
Old May 17, 2009 | 01:07 PM
vmcclain's Avatar
AC problem
My a/c is doing the same thing. Around about 70 degrees, it blows out warm air. Put it on 60 degrees, the air gets cool. Also, I noticed when my compressor kicks on, the car runs pretty hard sitting still. Could this be related to the low end hose?
