Need Help Pronto!!!!!
Old Dec 9, 2008 | 06:43 AM
GirlLiz's Avatar
I have a 2005 Maxima....
I'm having problems with my ABS......I will do my best to describe the problem.
When I'm between 5mph - 30mph it sounds like my ABS is struggling. It sounds like it is studdering. Also, between 1mph - 50 mph it sounds like my ABS motor is always on. When I'm at higher speeds, especially highway driving, it's completely fine. When I brake the ABS doesnt struggle either...until i get to 30mph that is. I thought maybe it could be a sensor???
When I am in Reverse everything is normal...
I went to my friends shop and pulled off the front two tires and the brakes, rotors, and calipers were just fine.
Should I take out my Fuse???? I dont want anything else messing up on the car, so I havent taken the fuse out.
And my ABS light is NOT on.
Any feed back would be great.....
thanks!
- Liz
Old Dec 9, 2008 | 06:47 AM
Juiced SE-R's Avatar
Sounds like a wheel sensor gone bad? I had some of the same issues with mine and I thought it was a wheel sensor but it was actually the sensor cable that had a peice of the coating missing from rubbing against my strut that was causing the problem.
Old Dec 9, 2008 | 06:55 AM
GirlLiz's Avatar
Hmmmm, I didnt think about that one. Thanks for the feedback!!!
Do you know how much that would cost at the dealership to get fixed?
I'm not very familiar with Nissan's. I've had my car since 06, so i definitely should be, but I've always been into DSM's.
Old Dec 9, 2008 | 07:13 AM
No problem. I have no idea how much it would cost, I didnt even let the stealership get a chance to look at it. I took it to the shop where I get my car tuned and they took it apart and heated up some shrink sleeve and when it cooled off it sealed to the old wire just like a new coating. I havent had any problems since, this was about 6 months ago so its still holding up well. I'm not 100% sure if thats what your problem is but thats what my issue was.
Old Dec 9, 2008 | 07:34 AM
2LEET4U's Avatar
so i take it, you have no warranty?
if yes, you might have a hard time getting the dealer to cover it.
Old Dec 9, 2008 | 08:33 AM
GirlLiz's Avatar
I have an extended warrenty, but I hate stealersh*ts!
Old Dec 9, 2008 | 10:36 AM
brio_max's Avatar
Learning English...
This is the only one TSB about ABS system. Maybe you should check it out. Good luck.
NTB07-016b.pdf
Old Dec 9, 2008 | 12:28 PM
Torgus's Avatar
pull the fuse...at least till you get it fixed.
Old Dec 9, 2008 | 01:06 PM
GirlLiz's Avatar
I'll Pull the fuse. Thanks everyone!
Old Dec 9, 2008 | 03:16 PM
Shoey1's Avatar
sometimes the sensors get covered in brake dust and throw out the magnetic signal generated by the notched ring on your CV shaft
Old Dec 9, 2008 | 04:00 PM
GirlLiz's Avatar
should this all make my abs motor stop running? especially if i pull the fuse?
Old Dec 15, 2008 | 10:43 PM
liljr415's Avatar
sounds expensive anything that had to do with abs usually is if you still have warranty take it to your dealer if not your gonna have to spend a couple hundreds
Old Dec 16, 2008 | 04:42 AM
00MaxSE's Avatar
Pointy Elbows
Liz, what did the dealer say yesterday?
Old Dec 16, 2008 | 05:24 AM
KCMAXX's Avatar
KC's FINEST
LOL @ 5 stars.
Updates?
Cipitiox
Jun 20, 2015 10:29 AM
Pronto
Jan 28, 2010 12:50 PM
Pronto
1/4 and 1/8 Mile Racing
Jun 27, 2007 02:39 PM
