Need a Quick Answer about a the rear hub
Old Dec 14, 2008 | 03:11 PM
-Sin-'s Avatar
Does the rear passenger hub (4 bolts) come out without having to do anything to parking brake or is it physically attached to the parking brake? I need to get my car back together.
Old Dec 14, 2008 | 05:41 PM
oldngivout's Avatar
Willing to learn
The bolts that secure the hub assembly also hold the backing plate for the park brake. The plate is between the hub and the knuckle.
Old Dec 14, 2008 | 06:16 PM
-Sin-'s Avatar
Yup got the 4 bolts but on the back there are also another three bolts, 1 is for the parking brake cable the other 2 I am guessing is holding the parking brake to the knuckle. If I only took out the 4 bolts on the hub behind the knuckle shouldn't the hub come off leaving the parking brake attached to knuckle? Or is there other bolts I am missing?
I am hoping to take the hub off only if possible.
Old Dec 14, 2008 | 08:37 PM
oldngivout's Avatar
Willing to learn
No, you must disassemble the entire thing, because it's all bolted together. I don't think you can remove the hub without removing both brakes. Not sure about the extra 2 bolts. Do they hold the caliper on maybe?
Old Dec 15, 2008 | 05:17 AM
-Sin-'s Avatar
I already removed the caliper bolts, the extra 3 bolts are at the bottom of the knuckle.
The TSB's diagram looks like the hub was only held on by four bolts and looking at the hub it self it should come straight out.
If I have to take out the parking brake, do I have to loosen the adjustment bolts in the center console to remove the cable or is there some trick to it?
Old Dec 15, 2008 | 10:22 AM
-Sin-'s Avatar
Hmmm, I thought more people did the wheel sensor TSB on there own... Could I be wrong...
Old Dec 16, 2008 | 05:52 AM
-Sin-'s Avatar
It's held on by four bolts, no need to take off the parking brake to remove the hub but necessary to grind per the TSB
Tiniform
Dec 25, 2015 07:40 AM
Maxima_Joe
Nov 25, 2015 08:19 AM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
soloist3
29
Sep 1, 2015 03:47 PM
