Confused and in fear of drivetrain trouble!!
Old Feb 2, 2009 | 11:48 AM
baldo2104's Avatar
Ok guys this ones kinda scaring me and from what I hear Nissan would be of no help. For only about the past 3,000 miles have I noticed this. While cruising at 60 or above there is mild but noticeable vibration that I cant identify to be coming from any certain area. Here's whats got me worried. If you let off the gas and coast it dissapears. As soon as you add any throttle even a little to maintain a speed its back. I had the fronts rebalanced but no effect. My brake rotors are slightly warped, but I dont think that can explain this can it?
Old Feb 2, 2009 | 11:56 AM
Icons04SilverMax's Avatar
Bad tires??? check for bubbles.....
Old Feb 2, 2009 | 12:05 PM
baldo2104's Avatar
I ruled out tires or rotors because its perfectly smooth while coasting 60-80mph. Only when you add any amount of throttle does it become prevelant.
Old Feb 2, 2009 | 01:03 PM
VigilanteMax's Avatar
miles on car?
Old Feb 2, 2009 | 01:52 PM
baldo2104's Avatar
Little over 51,000 miles. 06 5sd AT.
Old Feb 2, 2009 | 02:13 PM
Lovemycar's Avatar
Motor mounts mybe
Old Feb 2, 2009 | 02:26 PM
Fiddy Yen's Avatar
Its vibration from the motormounts. Basically if your car is cruising and its in a higher gear, it will vibrate as u press the accelerator because its in a "cruising gear". I've had this on my older modified car when I upgraded my motor mounts. Its not a huge deal, its not like they are broken or anything. its more like the motor mount is stiffer, and the vibration is carrying forward to the interior of the car.
I have the same thing on my current max, I just choose to ignore it as it doesn't bother me. Turn up the stereo, you wont hear/feel a thing.
Old Feb 2, 2009 | 06:41 PM
pmohr's Avatar
No more Maximas...
You lowered at all?
Bad axles will give you the same symptoms.
Old Feb 2, 2009 | 08:41 PM
baldo2104's Avatar
Thanks Fiddy Yen! That sounds to me like a logical explanation. Ill try to get a look at motormounts to verify, but til now Ive been completely stumped.
Old Feb 4, 2009 | 06:50 PM
Fiddy Yen's Avatar
no prob.
I think there might be a recall or TSB on this as well. You should double check.
Old Feb 5, 2009 | 04:37 AM
Burny's Avatar
where can you get a list of recalls for the Max?
Old Feb 5, 2009 | 03:36 PM
Fiddy Yen's Avatar
I checked yesterday to see if there was a TSB on the motor mounts... I was wrong...
But here is a list of the TSB's.
http://maxima.theowensfamily.com/tsb...=2004&tsb=none
Old Feb 5, 2009 | 04:25 PM
gen2000's Avatar
And here is a list that is more up to date.
http://x.nissanhelp.com/forums/Knowledgebase/links/211
Old Feb 17, 2009 | 09:21 PM
trauma911's Avatar
Maybe the axle/CV joint
I have a similar problem with my 2005 maxima, 6sp manual, only 28k miles. Got 4 new wheels, 4 new tires, balanced 3 times, 4 wheel alignment, also had warped rotors which I had machined and the problem still exists.
When I took the car to another mechanic (after 3+ visits to nissan dealership with no resolution of symtoms) he immediately recognized that vibration that is worse with throttle and resolves when you let off the gas is often due to a back CV joint.
Anyway, turns out this doesn't seem to be my problem as my vibration now continues even when I let off the gas. I would have posted a new thread since I am describing a new problem, but as a new user I don't seem to have privledges to post new threads. Anyway, I get vibration, very noticable above 60mph, but seems to improve occasionally at specific speeds (very narrow window). I noticed today that the vibration was improved at 80mph, 88mph, and 100mph. I'm completely lost and confused as to the cause of this (I believe I have ruled out a tire, wheel, or alignment problem as these have all been checked multiple times). Any new suggestions. Sorry for the long reply and not being able to post a new thread.
Old Feb 17, 2009 | 11:28 PM
Revs2Hard's Avatar
BARF
I could be wrong but its just somemore input. cant hurt right?
I had the same kind of problem on my 5th gen and it ended up being a RF wheel bearing and hub. Jack the car up and shake down the front end, its worth a try.
Old Feb 18, 2009 | 04:49 AM
trauma911's Avatar
thanks Revs2hard
I appreciate the input. Someone else told me the same thing so I will definately get it checked. btw, what do I need to do in order to be able to post new threads?
Miket2006
Mar 1, 2021 03:55 AM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
D Mason
Jun 21, 2016 04:43 AM
AboveDaCloudz
Oct 8, 2015 11:25 PM
zmcneely13
Sep 26, 2015 02:26 PM
