New Racingline FSTB
you have 2 options, 1) unclip the line and place it in front of the white clip or (2) slightly bend the gold bracket a touch flatter to push the line forward. Looks good though!
I have a Stillen FTSB but they have a similar issue. I removed it from the plastic clip and as an added safety precaution I used a zip tie and secured it to the bigger line to the right which tends to pull it away for no chance of rubbing!!! ~0_0~
[I put a small piece of scrap wood under it while I drilled so I wouldn't drill into the inner fender]
the new location of the white clip that holds the AC line in place is now more toward the
engine & the front of the car so now there is more clearance at the AC line & the FSTB
I drilled a new hole in the gold colored bracket [I put a small piece of scrap wood under it while I drilled so I wouldn't drill into the inner fender] the new location of the white clip that holds the AC line in place is now more toward the engine & the front of the car so now there is more clearance at the AC line & the FSTB
^ Try this, loosen the mount [there should be a little play in the mounting holes]
& relocate for the needed clearance. Grinding may the only answer tho
MaximaDrvr
Aug 19, 2015 08:20 PM
