code
Old Feb 6, 2009 | 05:02 PM
tonedef's Avatar
code
05 altima SER
P1273
AF sensor???????????????????????
lean shift detected
how would i find which o2 sensor this is????
i have a cattman y pipe with no cat, just the pre cats on the headers...stock headers.
keep in mind this car has the wideband o2 sensor
bad o2????
Old Feb 7, 2009 | 02:17 PM
tonedef's Avatar
bump
Old Feb 7, 2009 | 04:08 PM
po8pimp's Avatar
Ok so I looked up the code and it is O2 sensor for bank 1. Bank one is the side towards the rear of the car. Here is a link to NissanHelp: http://x.nissanhelp.com/forums/Knowledgebase/links/16 You need to register for free of course before you can download the PDF file named "EC" or Engine Control. At the top under search type your code in P1273 click enter and follow the Diagnostic to the best you can. You are more than likely going to have to replace that sensor. Good luck and if you run into a snag let us know.
Old Feb 7, 2009 | 04:34 PM
tonedef's Avatar
thanks bro, i appreciate it.
i didnt even know about that site.
Old Feb 7, 2009 | 05:01 PM
tonedef's Avatar
wow, that is alot of stuff.
to me it looks like it is the front top o2 sensor, the one before the cats.
could this be the cause of a bad exhaust leak for the past couple of weeks? the leak is fixed now, but i am thinkng maybe i damaged it.
Old Feb 7, 2009 | 05:39 PM
po8pimp's Avatar
a bad exhaust leak before the O2 sensor will cause a bad reading. A bad leak after will do nothing to the sensor. I recommend you clear the code and wait to see if it comes back. If it comes back then replace the sensor. To clear the code disconnect the neg battery terminal for at least 1 min then hook it back up. If it clears your good if not try again with it disconnected for 10 min. If it doesn't clear after that then get a new sensor and install it. The sensor should be the back top O2 sensor before the cat. The front sensor would be on Bank 2 not 1. You want Bank 1.
Old Feb 7, 2009 | 05:58 PM
tonedef's Avatar
k, thanks man.
i had auto zone clear it and it came back after a while.
q: since the SER uses wideband o2 sensors, would that mean all of them are wideband? and where can i get these sensors?
i tried a part search, but no success yet. i will keep looking
Old Feb 7, 2009 | 06:20 PM
po8pimp's Avatar
I will see if I can find em for you.
Old Feb 7, 2009 | 06:24 PM
po8pimp's Avatar
http://www.trademotion.com/partlocat...06&catalogid=1 Here is what you want for the Altima SER. I found it cheaper below.
Old Feb 7, 2009 | 06:32 PM
po8pimp's Avatar
http://shop.oreillyauto.com/ProductL...=Oxygen+Sensor Sorry I honestly didn't know you had an Altima SER. I assumed it was an 05 Maxima. I seriously just glanced at that part. Here is what you want. Shucks/Checkers autoparts store.
Old Feb 7, 2009 | 06:42 PM
po8pimp's Avatar
Here are a couple stores near where you live. Hope this helps. 4634 Everhart Rd, Corpus Christi, TX‎ - (361) 906-0955‎, 4102 Crosstown Expy, Corpus Christi, TX‎ - (361) 855-4845‎, 711 Oak Park Ave, Corpus Christi, TX‎ - (361) 888-6338‎, 5798 Weber Rd, Corpus Christi, TX‎ - (361) 855-5388‎, 5809 S Padre Island Dr, Corpus Christi, TX‎ - (361) 992-2884‎, 5801 Saratoga Blvd, Corpus Christi, TX‎ - (361) 992-5061‎, 10935 Leopard St, Corpus Christi, TX‎ - (361) 241-9655‎, 14033 Northwest Blvd, Corpus Christi, TX‎ - (361) 387-0386
Old Feb 7, 2009 | 06:45 PM
tonedef's Avatar
damn bro, u are the search king!
no seriously i hope i can assist u with something in the future cause u helped out alot.
thanks
Old Feb 7, 2009 | 06:49 PM
po8pimp's Avatar
no problem that's what we do here.... Take care of each other... Good luck hope all works out.
Old Feb 16, 2009 | 01:42 AM
Nevermore's Avatar
Rob, ever get the o2 fixed?
Old Feb 16, 2009 | 07:50 AM
tonedef's Avatar
not yet, in the shop........can we say nitrous
Old Feb 16, 2009 | 09:24 AM
Apollos2's Avatar
"Nitros fixes everything"
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
