6th Gen Max Seafoam and In Cabin Air Filter Maintenance Videos
Old Feb 11, 2009 | 04:56 AM
  #41
myer84's Avatar
Originally Posted by chernmax
- The car will produce moderate to heavy smoke for about the first 5-10 minutes. The more you drive the faster it will dissipate.
- My check engine light flashed for about 30-45 seconds
- Why didn't you clean the throttle body before you put it back on??? IMO no, I wouldn't use it because of it's patrolum base and residue may cause more buildup of dirt. Plus I didn't see it listed on the bottle but I could be wrong.
I really wanted to clean my throttle, but I heard it's not good to touch the plate on the throtle. I heard many people have ruined this and had to pay a lot to get it fixed. I plan on using seafoam soon, but I would also like to clean the throtle. I also plan on adding the oil catch cans to avoid future oil residue buildup. Any recommendations on getting the throttle cleaned up?
Old Feb 11, 2009 | 08:36 AM
  #42
Torgus's Avatar
seafoam is great. i'v never used it but i think i may on my 92 for ****s and giggles. only downside is it's known to clog up cats with all the crap you're putting through it.
Old Feb 11, 2009 | 11:34 AM
  #43
chernmax's Avatar
Nations 1st 6th Gen Turbo
Haven't heard that but then again I don't have precats and I have a high flow cat and have not thrown any codes...
Old Feb 11, 2009 | 11:35 AM
  #44
chernmax's Avatar
I cleaned mine by hand with windex and paper towels!
Old Feb 11, 2009 | 05:54 PM
  #45
myer84's Avatar
Wow, Lol. I been doing some research. I'll go ahead and clean it and just be carefull with not touching the butterfly. Thanks again
Old Feb 13, 2009 | 03:55 PM
  #46
nyc10034's Avatar
Alright, so yesterday I put Seafoam into my throttle intake(the little hole coming out the engine, just like in the video). I did not have nearly as much smoke coming out as in the video. I had about 4 seconds of smoke coming out of my exhaust, after driving off for about 2 minutes. My engine DID turn off 3-4 times while I put the Seafoam through the hole, with the same type of funnel in the video. So either I did not have much carbon buildup or I did not use enough Seafoam. However, I did use a little more than a third of the Seafoam, I'll say between 1/3 and 1/2.
Old Feb 13, 2009 | 07:23 PM
  #47
chernmax's Avatar
You won't get as much smoke if only applied to the intake maifold of the engine so it's normal. As you're driving more will burn off (smoke) just not as dense.
Old Feb 14, 2009 | 02:25 PM
  #48
rydesteel's Avatar
Chern, Thanks for cabin filter vid. I just changed mine this afternoon after watching you make it look easy. Took a few minutes longer this time than it took you but the next time will be easier. 26,000 miles, how's all that cr*p get in there anyway :>). Enjoy the day. Frank
Old Feb 14, 2009 | 03:35 PM
  #49
chernmax's Avatar
Thanks, glad to help!!!
Old Feb 15, 2009 | 07:20 AM
  #50
Y2k2maxse's Avatar
Very nice write up - good camera job also video was really good lots of detailed info. hope to see you at maxus man
Old Feb 15, 2009 | 09:30 AM
  #51
chernmax's Avatar
Thanks for the props and I'll be at Maxus...
Old Feb 15, 2009 | 09:51 AM
  #52
execstyle's Avatar
nice man i'll def try it out,
Old Feb 17, 2009 | 02:45 PM
  #53
DConrad2007's Avatar
I changed my incabin filter a few months ago and while putting the two hinges back on one fell behind the underdash.Do anyone know where i can find this part or do anyone have a extra one laying around?
Old Feb 17, 2009 | 04:02 PM
  #54
chernmax's Avatar
Try a junk yard or just pull the other one out, take it into a Lowes or Home depot and in the special hardware sections find a push pin about the same diameter or find a large size smooth nail with a flat head, measure, cut the pointy end off and use that!!!
Old Feb 18, 2009 | 08:12 PM
  #55
Kryogen's Avatar
Changed it again after 1 year. Not that bad..... was a bit black, tree bits, some insects, pollen, but nothing terrible. Bah, I have allergies, and 30$ for clean air.... its ok.
Old Feb 18, 2009 | 09:15 PM
  #56
LiquidIce's Avatar
Nice videos and write up chern. I am a brand new 6th gen owner to the forums and love this DIY type of stuff. Thanks again for the tips! Keep them coming
Old Feb 18, 2009 | 09:32 PM
  #57
studious04maxima's Avatar
I just tried this on my jeep and f150 and the results were minimal but you can feel the difference in the throttle response. i will also try on my max this weekend if i get the time. EXCELLENT VID!!!
Old Feb 19, 2009 | 05:57 AM
  #58
chernmax's Avatar
Don't forget the oil change after seafoaming!!!
Old Feb 19, 2009 | 11:38 AM
  #59
KC2010's Avatar
Chernmax is a great guy! You should do more vids like this. How about a "How to drop you sub-frame" vid?
Old Feb 19, 2009 | 12:07 PM
  #60
chernmax's Avatar
Then I would have to do it all over again but looking at the pictures you can get an idea of how it looks once pulled down with minimum disconnecting. The key is supporting the engine and help to lower the subframe!!
Old Mar 8, 2009 | 11:57 AM
  #61
hmr1979's Avatar
ok I finally have some time to do this and am very close to my next oil change
can someone please tell me where the oem im vaccum hose is on this picture. I do not want to start pulling stuff I am not suppose to. I am assuming it's still on the left hand side so I took the pic towards that area. thanks in advance
[IMG] [/IMG]
Old Mar 8, 2009 | 12:36 PM
  #62
SmokeNismo's Avatar
its the one connected to the top of the intake manifold there on the left, to the right of the round black circle. To check you can turn the engine on and pull off that tube and see if it's sucking in air from the manifold.
btw, could use an engine wash =))
Old Mar 8, 2009 | 01:09 PM
  #63
chernmax's Avatar
[IMG] [/IMG]
The only hose on the left going into the front of the Intake Manifold...
Old Mar 8, 2009 | 03:00 PM
  #64
hmr1979's Avatar
thanks! i figured it was that one, but i wiggled slightly and its on there tight so i was just making sure it was that one
thanks everyone
Old Mar 8, 2009 | 04:32 PM
  #65
chernmax's Avatar
thanks everyone
Use a flat tip screwdriver from the back and work it forward while pulling on the hose. Just pulling on the hose will actually make it harder to get it off...
Old Mar 8, 2009 | 07:53 PM
  #66
hmr1979's Avatar
Cool! It's actually very easy to pull off, i just wanted to make sure that it wasn't something permanently on there
Anyways, did it this afternoon. Did all the procedures exactly as the bottle and your video said...quite a lot of smoke, but not as much as I thought there would be. I mean I reved it for a good while and the smoke dissipated pretty rapidly.
One thing I didn't know is how much fuel to have in the tank while doing this. Someone where I bought the seafoam said it's better to have at least half a tank of gas in. Anyways, I had about 60% of fuel in the tank.
I'll change my RP first thing in the a.m.
Old Mar 8, 2009 | 09:04 PM
  #67
Kryogen's Avatar
Worth sending seafoam in a 04 max? Seafoaming my 92 tercel helped alot cause it was full of crap and I didnt fear ruining it, but a 04 max with 50K miles???
Old Mar 8, 2009 | 10:35 PM
  #68
chernmax's Avatar
Why not??? And how will Seafoam ruin a car???
Old Mar 9, 2009 | 05:35 AM
  #69
hmr1979's Avatar
btw, no codes thrown at me yet, about 60 miles after the procedure.
i guess that's good?
Old Mar 9, 2009 | 09:35 PM
  #70
SmokeNismo's Avatar
ahh ya, i tried it and it comes off pretty easy, but i wanted to pull the other end of it so I can use it as a straw but the other end seems impossible to pull off. I'm gonna try to use an actual straw to see if that works when it comes time to doin it next week.
Old Mar 9, 2009 | 09:41 PM
  #71
SmokeNismo's Avatar
u mean no SES light right after the procedure? that's good I was expecting one when I do mine.
btw, I'm gonna do the 60k mile service at the dealer right after this also and it says on the list that they do a fuel system cleaning. I wonder what it is they do? Should I tell them not to do it and try to save a few bucks?
Old Mar 10, 2009 | 12:20 AM
  #72
chernmax's Avatar
Depends, what does your service manual say to do for 60K service?
Old Mar 10, 2009 | 05:41 PM
  #73
SmokeNismo's Avatar
The service manual doesnt say anything about a fuel system treatment. I think it's just part of the package offered by the dealer
Old Mar 10, 2009 | 07:42 PM
  #74
chernmax's Avatar
Can't hurt unless they are charging a rediculous price for it and you can go out and buy a good fuel system cleaner and pour it in your gas tank yourself. If your car is running good in your opinion, skip it!
Old Mar 17, 2009 | 01:13 PM
  #75
SmokeNismo's Avatar
Ok so I just came back from a seafoam treatment on the max. I did the 1/3 in the oil and 1/3 in the gas tank first. Then turned the engine on and put the rest into the intake manifold. Stalled once only. I then turned the car off and let it sit for about 10 mintues. When I turned the car on no white smoke was coming out until like a minute later. I then revved it a little smoked a good amount i guess for about another 2-3 minutes and stopped smoking. Then went for a spirited drive in some near by twisties.
My point is, I was expecting a bit more prolonged smoke, but I guess because the car hasnt seen anything buy 91 octane and synthetic oil there wasnt that much carbon build up to be burned off?
car feels slightly smoother maybe, but it could be psychological lol.
Old Mar 17, 2009 | 01:35 PM
  #76
chernmax's Avatar
Seafoam is a great preventative maintenance treatment for cleaning crankcase, fuel system and IM internals by using 1/3rd treatment on each area. I'm not sure how everyone seafoams their vehicle but most that smoke like hell have at least 1/2 a can or more dumped into their crankcase or IM. Anyway, don't forget the oil change...
Old Mar 17, 2009 | 02:30 PM
  #77
SmokeNismo's Avatar
ya im goin in for an oil change and 60k mile service in exactly one week.
Old Mar 17, 2009 | 09:55 PM
  #78
MaxEx's Avatar
I just put 1/3 in my crankcase tonight, and I didn't notice any smoking at all..none. I'll try the IM tomorrow, and I bet a lot will come out then. I don't know why I was expecting it. She only gets 93 octane and Pennzoil Platinum. 04 80k miles
Old Mar 17, 2009 | 11:21 PM
  #79
SmokeNismo's Avatar
Yea I dont think you would get smoke if you put it in the crankcase since you're not burning the oil its self. Therefore, no smoke from exhaust
Old Mar 29, 2009 | 08:03 AM
  #80
STARR's Avatar
Guess it's time to Seafoam my car, the Service Engine Soon light came on and when I took it into the dealer, besides being told I need a new Front Cat, they wanted to power flush my engine and do a fuel injection service
