Dash Removal 08 Models..?
Old Mar 24, 2009 | 02:38 PM
LucKie1nE's Avatar
Wussup everyone.. I've been searching on the org for the removal of dashs.. I got a lot of great threads on 04-07 models.. but the 08's dash is slightly different.. Has anyone every removed the dash apart off of an 08 including the radio and LCD screen..? If so, any instructions or pics on how to..
Old Mar 24, 2009 | 03:48 PM
Wantastic's Avatar
i had mine removed twice.. actually three times before. it's pretty easy. i'll try to get some pic for you.
Old Mar 24, 2009 | 10:48 PM
LucKie1nE's Avatar
Thanks wantastic..
Old Mar 25, 2009 | 06:46 PM
Wantastic's Avatar
sorry i don't have any good pics so hopefully this helps.
1. to remove lower dash first, it's easier to put your gear on N and pull gear change cover. then you can remove lower dash
2. using (-) screw driver, carefully remove clips on top two areas. one is on the right, and the other is on the left side. probably about an inch away from the corner.
3. there are two screws bolted on the bottom of upper dash. no clip there so you have to unscrew them. see the second picture.
4. then your dash cover will be out.
Old Mar 25, 2009 | 06:50 PM
Wantastic's Avatar
i hope this is what you were looking for.
good luck
Old Mar 25, 2009 | 08:00 PM
LucKie1nE's Avatar
Thankz for the help..
RealityCheck
Oct 2, 2015 06:34 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
salty318
Sep 29, 2015 01:21 PM
jaydot901
Sep 29, 2015 01:18 PM
salty318
Sep 28, 2015 07:22 PM
