wider tires
Old Jun 2, 2009 | 05:42 PM
A5703's Avatar
wider tires
Guys....I will need some new tires soon. I was thinking about jumping up to 255's...keeping my stock wheels. Will I have an issue with rubbing? Also, I guess I would have to get 255-40-18's? thanks
Old Jun 2, 2009 | 09:00 PM
SmokeNismo's Avatar
stock wheels are only 7.5 inches wide. They won't fit a 255 wide tire. Not safely at least.
Old Jun 2, 2009 | 09:12 PM
chernmax's Avatar
Nations 1st 6th Gen Turbo
255 ares more of a sidewall size??? I have them safely for 2+ years!!!
http://www.miata.net/garage/tirecalc.html
Old Jun 3, 2009 | 09:32 AM
eK9aT10pSi's Avatar
I don't think that calculator takes into consideration the rim width.
Old Jun 3, 2009 | 04:16 PM
SmokeNismo's Avatar
I thought your OZ rims were 8 inches wide. no?
Old Jun 3, 2009 | 05:27 PM
DeusExMaxima's Avatar
I believe stock rims only allow up to 245 widths. My 9" wide rims have 255 and I have had 265 widths on them and I have heard of 275 widths. But this is for wider rims.
Old Jun 3, 2009 | 05:52 PM
DrunkieTheBear's Avatar
Turbo'd Saab
http://www.1010tires.com/tiresizecalculator.asp
This takes into consideration the rim width.
The most you could do is actually a 225 on a 7.5 wide rim (225-40-18)
235with a higher series tire but it would throw off your speedo quiet a bit
On my 17x9s I had I could fit 275s on there if i wanted to
Old Jun 3, 2009 | 07:36 PM
SmokeNismo's Avatar
well the stock 6th gen wheels on the SE are 18x7.5 and they come from the factory with 24/45/18 tires. The sidewall sits flush, no stretching or bulging.
Old Jun 3, 2009 | 08:23 PM
Turbo'd Saab
Opps Sorry the thing didn't reset correctly when I was checking sizes early. My bad.
but 255s would still require an 8" wide tire
Old Jun 3, 2009 | 08:38 PM
LandsEnd's Avatar
I had 255-50-16 tires on my 1994 Firebird Formula, and that was a 8.0 inch wide wheel. 255 is the widest you can go on an 8.0 inch wheel safely, so 7.5 wide wheel wouldn't be safe.
Old Jun 3, 2009 | 09:08 PM
Turbo'd Saab
A tire shop shouldn't mount it...for liability purposes....I say shouldn't because i've seen some shops do some stupid things.
Old Jun 3, 2009 | 11:04 PM
DEADBOLT's Avatar
Go ahead... try me
Some shops will mount it, but they'll do it at YOUR own risk... it's like tinting front windows or windshield... you take the blame, but I personally wouldn't do it.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
