Have Anyone Seen This?
Old Sep 8, 2009 | 06:10 PM
thedelman's Avatar
My 05 Max is acting pretty weird. When the wheel is turned right I get the "Slip" indicator light and the car seems to be cutting off, but it's just not putting power to the wheels until the wheels are straightened or at least brought back past a certain point. It only happens when I'm turning or curving right.
Any ideas on what's causing it.
Del
Old Sep 8, 2009 | 06:54 PM
PetitFrereMaxima's Avatar
Weird! Never heard about that.
Old Sep 8, 2009 | 07:08 PM
po8pimp's Avatar
put it on a lift and have someone turn the wheel to the right while you watch to see if anything is getting caught. You could be pulling a wire or something. If you don't see anything take it to Nissan this could be a needle in a haystack problem.
Old Sep 9, 2009 | 05:30 AM
thedelman's Avatar
I'm thinking it has something to do with the Traction Control Sensor. Probably sensing a spinning wheel. I guess the Nissan dealer will get the chance to rob me!
thanks
Old Oct 7, 2009 | 11:48 PM
6thGenFTW's Avatar
Dude, it's gonna be a wheel speed sensor issue. Hit the TCS OFF switch and try turning see if it bogs. mine says slip at any speed above like 5mph. have to drive with TCS OFF or car cuts power til i come to a stop. Will be visiting a stealership, but saving $ first
Good luck tho
Pat
Old Oct 8, 2009 | 04:09 AM
maxed_out_saloon's Avatar
u should drive with the TCS off like 6thgentfw did. itll drive normal instead of driving and it cutting the power
