Question about size rims
Old Sep 15, 2009 | 03:15 PM
Kofi Armah's Avatar
Alright right now i have 20" rims on my max but saw a great deal on craigslist for a set of 22" rims. To the people who are riding on 22's how is the ride and is your max your daily driver? Do you all travel alot as well. I ask this because of course this is my daily driver and i travel around alot. I want to hear the pros and cons. if you were wondering what the rims look like here is the craigslist add.
http://memphis.craigslist.org/for/1376134812.html
Old Sep 15, 2009 | 03:33 PM
importcf's Avatar
idk if all that ugly could be crammed in there! Not really my style but how bout some info on ther car and i think there is a rim/tire sticky somewhere
Old Sep 15, 2009 | 06:55 PM
eK9aT10pSi's Avatar
+1 not my style as well. also some key facts you should find out is the offset & bolt pattern.
Old Sep 16, 2009 | 05:59 AM
Kofi Armah's Avatar
THE RIMS WILL DEFINATLEY FIT IM JUST QUESTIONING WHETHER I SHOULD GET 22" RIMS FOR MY DAILY DRIVER AND WHAT I WOULD BE GIVVING UP AS FAR AS PERFORMANCE. I ALREADY HAVE 20" RIMS ON MY CAR.
Old Sep 16, 2009 | 06:15 AM
digitalbow's Avatar
The seller doesn't provide specific dimensions/specs on the wheels. Are you sure they're even the right bolt spacing? Width, offset? How do you know they "definitely fit" BTW, CAPS LOCK is not necessary.
Assuming they're 8" wide, you'd have to run a 245/25-22 or similar tire size to maintain near-stock diameter (unless you want the 4x4 look), which would be a huge con for driving comfort, rim edge protection on road imperfections, etc. That's enough deterrent for me right there. Performance? More rotational mass = slower acceleration.
I can't think of a single "pro" except for maybe the 20"+ status that your ego and those of 16 year old kids might appreciate...
Old Sep 16, 2009 | 06:52 AM
po8pimp's Avatar
not bad for rims and tires. I would ask questions like mentioned above. offset, rim size, bolt pattern, Tread left on tires, how the other 3 look, why so cheap, are they stolen, etc. big purchase think long and hard before doin it. 22's will fit if you want them to. there are vids of a 6th gen maxima on 26's. As for performance loss, answer is obvious. Bigger rims=more wieght=more power needed to move them.
Old Sep 16, 2009 | 09:47 AM
wickedmax13's Avatar
I have 22's on mine...check my pics. It is used as my daily driver only about 100-150 miles a day. Mine are 22x8 on a Toyo 235/30/22 and they barely barely rub only when u turn the steering wheel all the way to one side...any bigger tire and you will have problems. Others may disagree bc it isnt their style, but I think it looks great how it fills the wheel well. Downsides: Acceleration, braking and constantly worrying about potholes or large bumps bc the tires are rubberbands. Surprisingly the ride is still about as smooth as the stock ride was. If the tires posted on craigslist arent this size I wouldnt spend the money on the set. New tires will cost btwn 800-1000. I got my wheels and tires mounted and balanced shipped to my door with locking lugs and hub rings for $1299 from a seller on ebay (silverwheellady). So if those tires arent the right size I would check silverwheellady out...I was very pleased with the service Terri gave me from there. Good luck
Old Sep 16, 2009 | 02:15 PM
KCMAXX's Avatar
KC's FINEST
Zzzzzzz.....
Old Sep 17, 2009 | 08:10 PM
Kofi Armah's Avatar
Sorry about the caps lock. The reason i said i no they would fit is because i called the gentleman and talked to him. and he said they were 5x114.3 with a 35+ offset. But i guess he could be not telling the truth. I will definately put the rims on and drive them before giving him any money. I am leaning on not getting the rims because of convenience of getting the tires when i need one. I pick up my daughter every other weekend from 6 hours away and would hate to have a blow out and not be able to find 22" tires. As i see it now the cons out weigh the pros.
Old Sep 18, 2009 | 10:48 AM
kenjio6's Avatar
i had 22's in my car and i was running a 255/30/22 tire if the rims are the right offset you should be ok
Old Sep 18, 2009 | 03:02 PM
chernmax's Avatar
Nations 1st 6th Gen Turbo
= increased stopping distance = higher potential for rim damage from pot holes...
Old Jun 12, 2012 | 11:05 AM
sturdi11's Avatar
question , got 18's on my max and wanted to know about the ride difference when i step up to 20's
Old Jun 12, 2012 | 12:02 PM
ShocknAwe's Avatar
Also if these rims are cast......they are going to weigh insanely high. The aspect ratio I believe will need to be about 25 so as not to make your speedo inaccurate
Old Jun 12, 2012 | 12:24 PM
NmexMAX's Avatar
dot dot dot ...
It's freakin 6th gen dude, come'on!
alahjahwan09
18
Sep 21, 2015 09:12 PM
kadespraggins
Sep 14, 2015 12:04 AM
0m3nc0w
Sep 11, 2015 05:21 PM
Maxima.KsA
Sep 8, 2015 11:33 PM
adamgalazka
Sep 8, 2015 01:27 PM
