Clutch Replacement - Most Economical?
Old Sep 21, 2009 | 06:53 PM
BlackSpeed's Avatar
Looks like its time to replace my clutch. Could someone recommend a good (not a wallet buster) aftermarket clutch?
Thanks in advance
Old Sep 21, 2009 | 07:42 PM
dmax04's Avatar
Clutch replacement
I don't know about economical, but I went with a Spec Stage 1 Clutch. Cost about $420
While I was replacing the clutch I also replaced the Flywheel and went aluminum, also Spec.
Old Sep 21, 2009 | 08:15 PM
NiZMo1o1's Avatar
look into a Southbend Clutch
Old Sep 22, 2009 | 03:35 PM
DeusExMaxima's Avatar
How much does your flywheel weigh and how does the car drive after the install? Does it have more power?
Old Sep 22, 2009 | 05:28 PM
dmax04's Avatar
To be honest, I don't know the exact weight of the flywheel, but now that I looked up the shipping weight it read: 30lbs.
It definitely took some getting used to the lightened flywheel, however. At first I hated it. I felt like I was a rookie learning how to drive manual all over again. Kinda embarrassing feeling the car jolt.
Anyways, in order for me to get out of first gear I have to give a lil more gas than usual, (I guess to get the momentum of the flywheel going).
Once I'm on the open road/highway the car accelerates noticeably faster. Pretty cool feeling.
Also, when the car is idle the sound of the flywheel is pretty obvious.
A friend of mine says, "That's what a tuner car is supposed to feel like"
Old Sep 22, 2009 | 05:33 PM
If you have the stock flywheel, can u wigh it? I would think the aluminum one would be around 13-15 lbs, not 30 lbs. How is the car sounding different at idle. Also, when you rev it up at idle, does it rev up and down faster?
Old Sep 22, 2009 | 05:42 PM
dmax04's Avatar
Sorry bro, but I don't have the stock flywheel anymore to weigh it.
Kinda sounds like a bike chain turning but not an overly loud sound. You have to pay attention to it.
And yeah, it does rev up and down faster.
Old Sep 24, 2009 | 10:35 AM
BlackSpeed's Avatar
Ok, so I decided to go with a Stage 7 clutch .. Seriuosly, I opted for the factory replacement kit for $179. Looks like the labor is going to be $350. Anybody in or around Atlanta want to tackle this job??
Old Oct 21, 2009 | 03:50 PM
now29's Avatar
I have a question? I have a 2006 maxima and I need a new clutch. what is the best clutch for me that will grab nicely but still be a comfortable ride. (want it for more speed) I dont want it to be too cheap but it cant be to expensive. but feel free to give me your opinion on anything. Also should I get a stage 1 or stage 2?
Old Oct 22, 2009 | 03:33 PM
lobewiper's Avatar
How will a different clutch result in more speed???
Old Oct 22, 2009 | 04:27 PM
now29's Avatar
the faster and smoother the clutch grabs makes the car have a little bit more "get up and go" power, which results in a little more speed.
Old Oct 22, 2009 | 04:34 PM
lobewiper's Avatar
O.K., but why would a lighter flywheel be "faster and smoother?"
Old Oct 22, 2009 | 05:01 PM
knight_yyz's Avatar
Toolie
exedy replacement OEM or exedy stage 1, has a bigger disk than the oem.
But if money is no object and I was going to do it all over again I would get a bully stage one dual friction. I know a few people who have this clutch and they love it.
CorollaULEV
30
Aug 9, 2021 08:11 PM
dinososexy2.6
Aug 31, 2015 05:37 AM
vanebecker
Aug 17, 2015 08:24 PM
