Changing front maplights
Hey guys, does anyone know how to open the front maplight lens cover on an 07? The 2 diagrams on page 8-29 of the manual don't match my maplight (mine doesn't have sunroof). I can't find anything using search either. Can someone tell me which piece to pry open (grey piece or clear piece)? and which corner? Thanks in advance!
i did a review on this... hold on lemme getcha a link.
basically all you do is stick a small flathead screwdriver in between the plastic lense and the overhead console.. and it should pop the clips out.
http://www.6thgenmaxima.org/forums/viewtopic.php?t=6494
I soo had to ask how this is done. I will like to change my bulds too. Now, all I need to do is buy the led bulbs.
Nick, thanks for the link.
Now, my question is where do I get some good leds. Any ideas?
i wanna say they are wedges... and the rear domes are festoons... BUT i am not sure.... contact Maxxpower @ MaxPowerCustoms.com to be absolutely certain. (i also have an 07.)
I'm not trying to threadjack, but I'm really new here and I don't have enough permission to post my own thread. I am just trying to find out if anyone can tell me which package LED's to buy to replace the LED's in my info screen. I have an 04 and that is all I have left to complete my LED swap. I don't want to be without my screen for a week while I wait on parts to arrive. My gauges and buttons and switches are all red and white and look amazing... but the info screen is a BIG ORANGE BOX staring me in the face! ANY help would seriously be appreciated... Thanks.
194
TO REMOVE THE REAR DOME LENS COVER:
-Very simply take a small flat blade screwdriver and carefully pry the clear lens cover off. (you may accidentally pull the entire assembly out of the headliner, but, that's ok. It'll pop right back in.) Once inside, I removed and discarded a metal plate that was in there restricting light passage. I don't know why they put that in there??? Then I popped the old bulbs out and popped the new LED's (pictured below) in. EASY!
TO REMOVE THE OVERHEAD CONSOLE:
-To remove the overhead console you need to open the glasses holder and remove the phillips head screw that is in there. Next, you need to jam your fingers under the entire console (in between the console and the headliner) and pull down sharply. (I had you use quite a bit of force) The console will pop then pop out. It is simply held up there with that one screw and 4 clips that are hard as hell to pop out. HA! You just gotta yank it! Now you unplug the console and take it inside. For the LED's that I used I didn't have enough space to install them "as is".... so after removing the clear lenses (simply, but gently, pry them out) and the stock bulbs ...I had to remove the plastic cream colored backing plate that is behind the stock bulbs.//Picture of backing plate\\ After that I had enough room to install the LED's pictured below. These LED's were not 360 degree facing.... they just faced straight down... so I didn't need any type of reflective backing.
This is the rear LED's that I got from Autolumination.com (3022 / 29mm):
This is the front map light LED's that I got from SuperbrightLEDs.com(194 wedge style):
I hope this can help someone because I couldn't find any detailed instructions on this mod. Only bits and pieces of info that I was looking for. Maybe this could be a sticky?
mtndewnut, not sure if you realized you replied to a post that was over 2 years old.
Good info though. And as for interior LED's, but them from me, link in my sig! Best quality and brightest around!
Yeah... they better be better than what I got... cause the price sure reflects that.... I spent about $30.00 on everything ..... and for me..... they are plenty bright .... MUCH better than stock . I do realize the post was old... but... like I had said... I couldn't find any specific "how-to's" on removing that overhead console. I thought I would add my $.02 and maybe it would push someone else over the edge and going for the upgrade. It's worth it.
I checked out your Max on Cardomain .... really nice ... I really like all of your upgrades!
MAXSE5SPD
Aug 23, 2015 12:06 PM
laparka66
Aug 6, 2015 09:36 AM
RealityCheck
Aug 5, 2015 06:18 AM
WHAT HE SAID
