shift lock help please
Ok Out of nowhere my shifter is locked in park and have to press down on the shift lock to put it in drive or reverse.I have to use it everytime I drive and it gets annoying.Is there anything that I can do fix this problem?Thanks
You have a manual or auto? the same **** happen in my auto and I discovered it was the Brake light sensor. There's 2 sensors that pop up when u press on the brake. One is for Cruise control and the lower one is the brake light. If the car senses the brake light is not on. The shifter will not be released. It's probably loose or something. I had mine replaced for 40 bucks through courtesynissan.com
please help
At a stop sign, my car would not accelerate. The engine was revving but the car was stationary. I look down and my gauges aren't working properly: 1) fuel tank reads empty 2) thermostat reads cold 3) odometer and speedometer are "dead"; 4) a/c is inoperable 5) car will not shift gears.
i had to move my car to the side of the road by removing the shift lock.
please help.
please help.
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
