headlight lense question
Old Nov 8, 2009 | 05:51 PM
jay3250's Avatar
hey i was wondering if anyone knows if it is possible to replace the headlight lense without replacing the whole assembly and where to purchase this online
Old Nov 8, 2009 | 06:14 PM
bigpopaj369's Avatar
whats wrong with urs? heavy oxidation or cracked?
Old Nov 8, 2009 | 06:30 PM
jay3250's Avatar
heavy oxidation. i cant stand it
Old Nov 8, 2009 | 06:44 PM
honestly id just save urself some cash and get a 3m resto kit or just wetsand them, this issue comes up alot here. i was in the same boat and i just went out and got a resto kit and they look 99% better. check this thread out maybe it can help http://forums.maxima.org/6th-generat...rs-hazing.html
Old Nov 8, 2009 | 08:21 PM
po8pimp's Avatar
also check out this thread http://forums.maxima.org/detailing/5...ing-issue.html I used the 3m restore kit and had a bit of trouble at first. I recommend 2000 grit sandpaper and mother's plastic polish. you have to use masking tape to tape around the headlights just in case, so you don't accidently scuff up the paint on the car. Then wet the sand paper, and make sure you keep it wet and don't allow it to buildup. keep wetting and sanding until a slight haze forms. Will look a little cloudy. then dry and apply the polish. Trust me this works. The 3m kit ruined my lights and this process saved them and about $1,000 of my hard earned money. The sandpaper is pretty much just paper. not rough at all but enought to get the job done. remember to keep it wet.
Old Nov 9, 2009 | 05:46 AM
jay3250's Avatar
i used the 3m resto kit and one side and did a side by side comparison. the side i was supposed to be restoring is hazed now worse than the other im not sure all i did was follow the instructions
Old Nov 9, 2009 | 07:07 PM
i would tryout po8pimp's method see if it gets better, are u using any lense clarifying compounds?
Old Nov 11, 2009 | 04:02 PM
po8pimp's Avatar
That is what happened to me with the 3m kit. I am trying to warn you guys about it. Use my method, it will fix the problem. I was in your shoes with the 3m thing and this was recommended to me so I said WTF why not can't get worse. It fixed the problem completely. Good luck and any questions just ask.
Old Nov 14, 2009 | 07:18 PM
SteadyC's Avatar
If its to the point where you are considering new lenses, find a real auto detailer (NO drive-through B.S.). At our shop we have to do this at least once a day. We do almost exactly as po8pimp said but we use a high speed buffer with a finishing pad to finish the job. With the 3M resto kit they provide you with what we call a cutting pad, the problem is you cant finish with a cutting pad. A cutting pad will leave it looking even but still hazy. If you are going to try it yourself the only thing I would add is to soak the wetsanding paper for 15 minutes in water and car wash soap prior to wetsanding. Use the soapy water as your lubricant to wet sand. My .02 is find a quality detailer and you will save a lot of time, effort and money.
Old Nov 14, 2009 | 07:28 PM
Just buy some Brasso, mask off the paint around the headlight and buff it out.
Old Nov 15, 2009 | 10:21 AM
jsmithsole's Avatar
*moderator*
I tired a couple of different kits (not the 3m one) but they never came out good. I just had them professionally done and they look like new, $20 per light. Best money spent!!!
Old Nov 15, 2009 | 10:37 AM
ButtaMax's Avatar
3m worked wonders for me, MORE THEN SATIFIED........
5.5 headlights thou
AaronL
Nov 15, 2020 11:52 AM
03VQMAX
Nov 10, 2015 03:39 PM
Vistance
Sep 17, 2015 05:17 AM
mpbclutch33
Sep 8, 2015 06:21 PM
sdotcarter
Sep 2, 2015 09:53 PM
