alternator replacement
Old Dec 1, 2009 | 09:04 PM
ChromeSE5's Avatar
My alternator is talking a dump at 54k. I have a 2007 and was wondering if its pretty straight foward. I have done an AC compresor swap on my 5th gen and seems to be the same idea except I don't have to unplug any hoses. Let me know what I can look foward too and any tips. I searched "alternator" and got two hits for the 6th gen forum.
Old Dec 3, 2009 | 08:17 PM
BOOTZ's Avatar
i've got the service manual. I'll see if I can pm it to you.
Old Dec 3, 2009 | 08:38 PM
ChromeSE5's Avatar
I found the FSM on nico club I think. Its helped out a lot. I am having issues removing the idler pulley though. The nut is pretty tough.
Old Dec 7, 2009 | 08:07 PM
BOOTZ's Avatar
Did u get it done? Did you end up removing the radiator?
Old Dec 8, 2009 | 09:09 AM
ChromeSE5's Avatar
yea its done. Wasn't as bad as I thought it would be. Removing the bolt that is on the lower part of the alternator sucked but what was worse was putting it back in. The bolt is about 8 inches long and it has to go in from the inside and the nut that holds it is right under the pulley.
I did have to remove the radiator and was lucky enough to have enough play in the cvt hose lines so that I didn't have to disconnect those from the radiator. The battery tray must be taken out so you have clearance to move the radiator.
Old Dec 8, 2009 | 09:33 AM
DAlastDON's Avatar
Originally Posted by ChromeSE5
yea its done. Wasn't as bad as I thought it would be. Removing the bolt that is on the lower part of the radiator sucked but what was worse was putting it back in. The bolt is about 8 inches long and it has to go in from the inside and the nut that holds it is right under the pulley.
Thats good stuff. Ill remember this when i put my 240amp alternator in. Hopefully before i kill the stock one with my audio setup. Only been putting it off for a year and a half.
Old Dec 10, 2009 | 08:35 PM
BOOTZ's Avatar
LOL! Sounds like me! I got mine from Excessive Amperage this past summer and been puttin off the install. Prolly gonna wait til spring now.
lowpost99
Oct 26, 2025 06:53 PM
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
TheMafia
Sep 4, 2015 08:26 AM
