Question about rotors...
Old Jan 17, 2010 | 06:12 PM
joemax1's Avatar
Hey guys. Its been a long while since I have posted here, but I still have my 04 Maxima with 127,000miles in it. Anyways, it's been problem-free so far except for the OEM rotors which I already had resurfaced 3x in the span of 5 yrs since I owned it. My question is, should I have it resurfaced again (due to "shimmy" in steering wheel when braking) or should I just have them replaced. And if I'll have them replaced, should I put in new brake pads too?
Thanks guys!
Old Jan 17, 2010 | 06:35 PM
MiamiBlackMax's Avatar
have you ever changed the rotors before? if not then you should change the rotors. If you decided change the rotors then you should changed the pads also so they can wear evenly so you wont have to resurface the rotors a few months later when you have to change the pads just my .02.
Old Jan 17, 2010 | 07:48 PM
Akfahad's Avatar
definitely just replace the rotors...hop on ebay and get a decent set of blanks or D&S rotors plus pads and do all four....don't waste your money on resurfacing.....
Old Jan 17, 2010 | 07:51 PM
blaxima06's Avatar
Definately invest your money in new rotors, don't even bother resurfacing your rotors. And yes, you might as well change your brake pads while your down there. I personally have Rotorpro Rotors with EBC red brake pads with no issue. Other people have the hawk pads, and some people use EBC rotors. Good luck joe!
Old Jan 18, 2010 | 02:37 AM
1hawaii50's Avatar
Buy decent rotors. If not, you'll be resurfacing the new rotors soon.
Old Jan 18, 2010 | 08:30 AM
BadBlackMaxSL's Avatar
Replace them, I went with Napa Ultra Premium rotors and Napa pads. Way better than stock.
How did they resurface the rotors 3 times when you shouldn't do it more than once? Those rotors probably will crack in half pretty soon.
Old Jan 20, 2010 | 07:50 PM
ZoomZoomZoom's Avatar
Who made the stock rotors? Anyone know?
Old Jan 20, 2010 | 07:54 PM
rohanmax14's Avatar
Nissan!
Old Jan 22, 2010 | 12:35 PM
maxout!'s Avatar
that shaking feeling ain't going go away with resurfacing. get new rotors and pads.
personally I like that shake n bake sensation.
drives the ladies wild n horny.
cheers.
Old Jan 22, 2010 | 02:22 PM
NIKV69's Avatar
You cut the rotors 3 times? I wouldn't go more than once. Get new rotors.
Old Jan 22, 2010 | 03:01 PM
VANGtastic97's Avatar
You could order the FRONT OEM replacements made by "Kiriu" from IRP in the GD's here on the forum for about $130 shipped. The rotors are painted at the hub too. I would have ordered them but ran into some timing issues, so I just bought some Autozone rotors. They have been performing well with Hawk HPS pads, which were about $70 shipped from www.performancepeddler.com with the "MAXIMA" discount code. Installing the parts took about 1.5 hours, and it was the first time I ever attempted to install front brakes myself. **Air tools helped a bit, but a breaker bar will suffice. I hope that helped the OP out.
Old Feb 18, 2010 | 08:20 AM
RitalinKid081's Avatar
Thanks guys!
On my 08 Max with 47K I experience a little shimmy'ing as well, I think i'll just buy some quality rotors and put some green stuff pads on with them.
Old Feb 18, 2010 | 11:10 AM
CXJ Performance's Avatar
Former Sponsor
http://forums.maxima.org/6th-generat...otor-pros.html
follow the link
Old Feb 20, 2010 | 10:31 AM
Tom1222's Avatar
I am also for looking for a decent set of Front Rotors. My wife's 07 SE has the Shake and Bake Syndrome. It started around 20k miles and now at almost 32k miles it seems to be getting a lot worse. I was going to go Autozone but heard that they start rusting if you don't paint the hat and I don't really want to mess with painting anything.
Is there a link to a decent set of Front Rotors. Just Solid not slotted or drilled.
Old Mar 5, 2010 | 11:15 AM
RicJamesMax21's Avatar
I'm looking to have my brakes done. hearing a little noise on the rear brakes, but no shimmy or vibration during braking. I checked on ebay and found some good deals on D&S rotors and pads. Has anyone here had any issues with the D&S rotors and pads offered on ebay?
Old Mar 5, 2010 | 03:45 PM
Tom1222's Avatar
I found these rotors and pads on E-Bay which seems like a GREAT deal
but are they any good? Does anyone have bought these and if so how
do they perform?
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
Old Mar 9, 2010 | 07:11 PM
SilverBeast's Avatar
New Rotors and Pads Upgrade or OEM ?
I like to know whats a better set up for rotors with pads all around.
Oem or upgrade ? please be specific on what brand name upgrade you recomend because I in need to do my 2004 SE 6spd. thanx
Old Mar 9, 2010 | 07:15 PM
Oolatec's Avatar
Guys, also check the group deals section here too... give fellow members some business!
I have front/rear slotted RTP rotors, which can be found here:
http://forums.maxima.org/group-deals...nes-fluid.html
And PBR/Axxis brake pads (Ultimates) which can be found here:
http://forums.maxima.org/group-deals...luxe-plus.html
Both products and sellers are great. I've had the rotors on my car for several years (one of the first mods I did after having the OEM rotors turned within the first 6 months of owning the car).
Old Mar 10, 2010 | 07:07 AM
Tom1222's Avatar
I just installed my own brakes and rotors with Autozone Rotors and C-Max Gold Ceramic Brake pads. It was pretty easy and I actually like the quality of the Autozone Rotors and the pads which come with all the necessary brake hardware like new clips and brake lube for the sliders.
Anyway, I have a question. My wife has been driving with the parking brake on at times and the parking brake cable is pretty stretched. Is there anyway to tighten that cable?
Thanks for any info on adjusting the parking brake.
Old Mar 12, 2010 | 02:19 PM
EBC
Has anyone maybe bhought these ebc rotors or similar to these ? How does the gold look on the car? http://www.autopartswarehouse.com/po...R1Y2UgdGVtcGVy
Old Mar 13, 2010 | 09:45 AM
tubs's Avatar
do they perform?
those do look like a good deal but i'm also wondering if they are any good. did you buy them? i see a few similar deals on ebay for slightly more money.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
