60,000 service?
60,000 service?
The 2007 SE is coming up on 60,000 miles. At about 50,000 miles, I flushed the radiator, had the brake fluid replaced, put on new belts. The oil & filter gets changed with M-1 every 5,000 miles. Tires (4) and all brake pads were done at 40,000.
I am not a big fan of preventive maintenance but was wondering if there are other items that are "mandatory" at 60,000?? The car is a daily driver that travels about 60 miles a day on the ATL interstates and we have had good luck with it for the past 2+ years.
I plan to run it to between 90,000 and 100,000 and then replace it.
Thanks in advance for any advice.
I change the air filter every 10,000. miles or so, so I'll get the tran fluid and fuel filter changed.
Do you know where the fuel filter is located and if I can get it without a lift??
Thanks for the replies.
Fuel filter in gas tank and does NOT need to be serviced.
my03maxima
Jul 28, 2024 07:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
