Lowering Springs on the 6th Gen Comparison
Old Feb 10, 2010 | 01:00 PM
DineroDave's Avatar
OK so let me know if I should take this down or move but I wanted to start a thread where everyone can post pics and describe their expiriences with the lowering springs they chose. Its a big debate that most of us have, which brand to go with? how will it ride? So lets see if this becomes helpful!
So please post what brand you got?
How much it lowered your car?
How it rides?
What shocks your using?
Any Problems?
And Pics!!!!
Old Feb 10, 2010 | 07:22 PM
MiamiBlackMax's Avatar
let the comments start ( btw there are about a trillion threads of pics and ppl comments on almost all springs for the ride)
Old Feb 11, 2010 | 08:09 AM
CXJ Performance's Avatar
Former Sponsor
ditto but lets make it short. progress with the kyb struts and shocks are the cheapest route with a drop of a little short of 2" in the front with 1.75" in the back ( i know the numbers arent exact to the teeth but very close ) ride is so so depending on the rubber and the rim size. i have 22's with that setup and its decent but i have a few more supension componets. my supension is about 30% stock and 70% aftermarket
Old Feb 11, 2010 | 08:11 AM
Former Sponsor
plus 1 on being from ct. i do the led swap and could help out with anything you want done to the car. i know this car all to well and have knuckle scars to prove it.lol
Old Feb 11, 2010 | 10:42 AM
phat99ody's Avatar
right now my car is factory,whats lowering springs should i get?
and also i need some shocks,which should i get.
im looking for something good and not to expensive
Old Feb 11, 2010 | 11:32 AM
Former Sponsor
please read
Old Feb 11, 2010 | 12:54 PM
VigilanteMax's Avatar
rear drop is a little off. i think you meant 0.75"
Best bang for the buck.
Old Feb 11, 2010 | 08:16 PM
LucKie1nE's Avatar
Brand: Tein S-Tech
Shocks: OEM
How It Ride's: Go Tein Or Go Home..!!..
RIDE HEIGHT
FRONT
Approx. Height Adjust Range
mm inch Max/Min(mm/inch)
-41 -1.61 -
REAR
-12 -0.47 -
Old Feb 12, 2010 | 11:49 AM
cfr94's Avatar
http://forums.maxima.org/6th-generat...ions-pics.html
I haven't had any problems yet with the lowering springs. Everything is still tight and once the springs settled, it rides even better I think.
Old Feb 16, 2010 | 06:24 PM
DineroDave's Avatar
I'm convinced! I'm goin wit eibachs!!! Gonna wait til my warranty, and this snow!, ends and I'll throw them on for April. Should get the 07-08 wing by the weekend, cant wait!
Old Feb 16, 2010 | 10:01 PM
04pearlwhitemax's Avatar
I did eibachs and kyb gr-2's up front waiting for the rear shocks to putthe springs as well but for the most part I love the way the car rides and handles up front big difference.
Old Feb 17, 2010 | 06:10 AM
TarmacSL1's Avatar
Originally I had H&R (1.4 Front , 1.3 rear) with OEM shocks, I just got a set of Eibachs and replaced the Fronts only leaving the H&R's on the back so now I am sitting ~2.0 Front and the ~1.4 Rear. Looks much better than before, Ride quailty is the same but only had them on since Monday so time will tell.
Old Feb 18, 2010 | 06:00 PM
theoriginalanimal's Avatar
i have a question though, im going to lower just the front 2" does anyone thing thats a bad idea, because i thought it would first even out the car and give it a good stance
Old Mar 19, 2011 | 12:04 PM
macakin's Avatar
reviving an old thread..
I installed only the front coils Teins with KYB struts, and it didn't lower the car that much I looks better non the less
Old Mar 19, 2011 | 01:20 PM
KevMaster's Avatar
Can you post pictures?
Old Mar 20, 2011 | 10:23 AM
macakin's Avatar
This is the one I got, I really didn't measure the drop but it doesn't look to be much, still looks better than it was
Updated the image size
Old Mar 20, 2011 | 02:45 PM
KevMaster's Avatar
Looks alright to me....or may be it's hard to jurge from small picture. You should wait few weeks for springs to settle down. Also you should install both front and rear springs at the same time.
Old Mar 21, 2011 | 09:16 AM
macakin's Avatar
I'm afraid to put the back ones cause then it would look lower in the back than in the front and I don't want that
Old Mar 21, 2011 | 11:26 AM
KevMaster's Avatar
Unless you're doing something wrong, tein springs shouldn't give you uneven drop if installing them on all corners. They drop pretty even when installed correctly which you did in your case. However one thing I can add is may be you've got counterfeit tein springs? There are bot load of counterfeit tein springs floating around. I heard stories that those counterfeit tein springs does not drop correctly and later they sags and get rusted. Where did you buy your tein springs from? Is that possible for you to take a picture of any/all markings on the springs itself including tein decale?
Old Mar 21, 2011 | 11:35 AM
bcampbe7's Avatar
Just because the fender gap looks even does not mean that the car sits level.
The gap in the rear will be less than the front.
Also, that does not look dropped in the front at all. Maybe it will settle.
Old Mar 21, 2011 | 12:16 PM
Rsprince89's Avatar
I just got a 2008 Max SL with 38k miles on it. What Can I do to it without Voiding out the factory warranty?
Old Mar 23, 2011 | 06:04 AM
tdark1582's Avatar
I am going wit the kyb and h&r springs. Just a small drop
Old Mar 23, 2011 | 06:26 AM
KevMaster's Avatar
Tein should give you a small drop but not H&R.
MAXSE5SPD
Sep 17, 2022 04:00 AM
95Maxi
35
Sep 2, 2015 10:37 AM
iflexsteel
Sep 2, 2015 08:04 AM
Lowered_a33
Sep 1, 2015 07:49 PM
