New Car some Problems
Old Mar 2, 2010 | 04:03 PM
2010MaximaSV's Avatar
I just recently bought an 05 Nissan Maxima SL. Starting the car seems kind of loud is this normal. Also its not a clock to run smoothly idling its a little loud. Also usually in any gear around 2k rpm I hear a soft grinding noise anything above that is fine. Anyone have any ideas. Any things I should look for. Also the splash guard underneth the car by where the oilpan is hanging down where can I purchase one with bolts and how much would it be? ANy inputs on the vehicle? The car also has 92,000 miles.
Old Mar 2, 2010 | 06:33 PM
NIKV69's Avatar
The grinding noise is probably the heat sheild. Nothing to worry about. Fasteners will probably be dealer only. As for the engine get a scanner and check your computer. Do the usual stuff like check air filter etc.
Old Mar 2, 2010 | 08:53 PM
Thank you very much I will look into that. Anyone else got any other ideas?
Old Mar 3, 2010 | 01:36 PM
It was the heat shield thank you very much.
Old Mar 3, 2010 | 01:51 PM
NIGHTMAREuki's Avatar
i think i have something similar but on 5.5 gen, when cars is cold first second cars rattles a lot, then gone, and between 2-3K rpms i hear this ticking noise from the timing chain area.
you should have someone accelerate while you listen under the hood to see if you can locate the source of the sound
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
Samedi
Aug 13, 2015 04:05 PM
erniel
Aug 8, 2015 09:32 AM
yat70458
Aug 3, 2015 01:16 PM
