HID Auto feature
Old Mar 11, 2010 | 07:56 PM
ray08max's Avatar
HID Auto feature
I use the auto light feature for my 2008 Maxima so my lights come on automatically and I don't remember having an issue before. But after I got my HID kit installed sometimes when I first start my car one side does not come on? It changes also which makes me wonder because its not always just the driver side or passenger, sometimes even both. Also, after I notice if I just turn them off then turn back on they will come on. Anyone else have this issue?
Old Mar 11, 2010 | 08:06 PM
Feldman's Avatar
its because there is a major fluctuation in voltage as your car starts. I just torn my non-OEM hid's off before i start my car then flip them on. Its like second nature for me now. I am sure there is a way to wire in a little capacitor by smooth the voltage out.
I am sure someone on here has the answer on this but obviously the cars with oem hid's dont have this problem and the ones without do once you swap hids in. What exactly is the difference?
Old Mar 12, 2010 | 05:10 AM
MadMax07SL's Avatar
Interesting, I wonder how that effects the aftermarket HID's in Fog lights...
Old Mar 12, 2010 | 06:13 AM
KCMAXX's Avatar
KC's FINEST
ebay specials?
Old Mar 12, 2010 | 01:17 PM
morteljc's Avatar
i have an 08 as well and aftermarket HIDs and never had a problem with the auto on/off feature.. even with my fogs...
Old Mar 12, 2010 | 04:56 PM
Terrentius's Avatar
I hate the auto feature.
Old Mar 14, 2010 | 08:29 PM
MiamiBlackMax's Avatar
i have had the same problem, i notice by just moving the cables or tappin on the ballast it turns on. I know what your talkin cuz I sometimes have to turn on and off be4 it turns on sometimes also. so I would recommend to check the connection also.
Old Mar 14, 2010 | 10:14 PM
morteljc's Avatar
well, if you had to do that kinda means that the problem probably is the hid set up itself... maybe the ballasts.. probably nothing to do with the car....
Old Mar 15, 2010 | 11:55 AM
timwdv's Avatar
if you wired your fogs straight to your headlights then you should be good, i had the same problem with the auto feature myself. When the lights turned off after i got out of my car they all turned off fine but after i got back in with the auto feature at night my fogs would flicker, like they werent getting enough voltage. I solved that by getting an inline 20 amp fuse on each positive (+) wire then ran a ground to the frame not using the black wire from the headlights. PROBLEM SOLVED!
Old Mar 15, 2010 | 11:23 PM
morteljc's Avatar
i didnt do any wire changes when i installed my heads and fogs... never flickered (hopefully wont ever) and all four lights do light up properly (as far as i know)...
Old Mar 17, 2010 | 09:42 AM
jamaxin97's Avatar
MadMax in The City
My left side wouldn't come on or when it did, the lighting output would be lower than the right side. I decided to get a set of 8k from a group deal. I was expecting them to be a lot brighter but they're not. The left side is still lower than the right side. I don't know what to do.
Old Mar 17, 2010 | 01:34 PM
morteljc's Avatar
aiming issues maybe?
AaronL
Aug 8, 2020 10:31 AM
BobTX10
Oct 7, 2015 08:43 AM
Maximeltman
Sep 28, 2015 07:19 PM
dshinn
Sep 26, 2015 08:07 PM
