Eibach lowering springs
Old Mar 23, 2010 | 08:37 AM
vmcclain's Avatar
I had the eibach lowering kit installed about three years ago. I've noticed that the inside tread of my tires wearing badly. Has anyone esle had this problem. I'm thinking maybe I need an alignment.
Old Mar 23, 2010 | 09:43 AM
Ryaliu's Avatar
alignment
Old Mar 23, 2010 | 09:46 AM
rock_drummer's Avatar
+1
Old Mar 23, 2010 | 10:25 AM
vmcclain's Avatar
Alright. Appreciate the help. I'm going to get that done asap.
Old Mar 23, 2010 | 10:47 PM
morteljc's Avatar
camber alignment.... due to the lowering of the car....
Old Mar 24, 2010 | 09:27 AM
vmcclain's Avatar
Should I get an alignment kit or just simply get an alignment.
Old Mar 24, 2010 | 10:40 AM
PrimedWick's Avatar
I'd have it done professionally if you've never done it by yourself before.
Old Mar 24, 2010 | 10:53 AM
njmaxseltd's Avatar
Did you have the car aligned after you put the springs in?
If not, you've been driving around toe out, which explains the abnormal ware.
Old Mar 24, 2010 | 04:00 PM
morteljc's Avatar
camber kits should fix it....
Old Mar 24, 2010 | 09:55 PM
L.E.Sentra's Avatar
camber kit will fix your alignment but your tires are fawked. they will continue to wear in the same pattern. do the alignment when you get new tires to keep tire wear even
Old Mar 24, 2010 | 10:51 PM
RAZ76's Avatar
Tire wear due to lowering would cause the inside of the tires to bold due to a negative camber. He is experiencing wear on the outside of the tire, too much positive camber. People that experience positive amber that wear out the outside of their tires are people with lifted trucks and a bad alignment.
Just get an alignment and you will be good to go.
Old Mar 25, 2010 | 09:00 AM
vmcclain's Avatar
Alright thanks guys. I'm going to go get an alignment this weekend. Gonna have to hold off on the tires. I don't drive the car much anyway. I just wanna get that alignment problem squared away.
Old Mar 25, 2010 | 03:47 PM
sensfan1111's Avatar
First post he says that the inside is wearing bad.....
Old Mar 25, 2010 | 05:11 PM
chris350's Avatar
there is a camber kits for eibach springs?
Old Mar 25, 2010 | 09:23 PM
morteljc's Avatar
yes... product # 5.81260K... just google it...
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
