Car shuts off in neutral
Old Jul 5, 2010 | 02:06 PM
6ThG3NMAX!MA's Avatar
Hi Guys,
I have a 2005 maxima SE 6speed. My issue is that my car will struggle in idle and eventually shut off. has anyone had a similar issue or have an idea what can cause this problem?
Old Jul 7, 2010 | 12:29 PM
dayyummCYNTHiA's Avatar
my problem with my shut off on a Honda because of the idle air control valve. =/
but I haven't had the prioblem on the Maxima. I would assume,, that it may be similar. My engine turned off when i Made a turn and almost hit the curb. geee.. good luck!
Old Jul 7, 2010 | 05:50 PM
po8pimp's Avatar
there is an idle air control learning procedure. I recommend doing that and see if it still happens. make sure you don't have an intake leak somewhere. that is a huge culprit to these type of issues.
Old Jul 8, 2010 | 05:21 AM
I did replace my Intake with an Injen CAI and checked it out the other day but it didn't look like that was the issue. Also checked the filter to make sure its not damaged. I was getting a P0441 code for the EVAP and checked the evap canister and didn't find an issue with that. I did find a bad vent control valve and changed it but that won't help my issue with the car dieing and I still have a SES light on.
Hondarydr
Dec 30, 2024 06:15 PM
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
erniel
Aug 8, 2015 09:32 AM
