Replacing Engine pulleys belts.
Did a search and to no avail it seems we're missing alot of servicing quesetions. Just curious if anyone has replaced the engine pulleys. I'm referring to the Water pump, alternator, and idler belts. After looking at the engine bay, the easiest way to access everything is to remove the passenger wheel and the splash shields. Will that expose the pulleys and allow better access for replacing the belts and adjusting the tension?
I just had to adjust both of my belts. One was loose, and the other was too tight. The belts would squeal when you first engaged the AC. I removed the front passenger wheel, and the splash shield. Once I figured out how to loosen the adjuster pulley's, everything was very easy. It took me longer to figure out how to loosen the pulleys than it did to actually adjust the belts. Now....no more squealing! As far as replacing the pulleys go...I'm not sure if you would need a puller to get any of the pulley off. If so, you're not going to be able to get a puller onto all of the pulleys...not enough room...so you may end up having to remove some things.
http://forums.maxima.org/6th-generat...stall-udp.html
http://forums.maxima.org/6th-generat...hodox-udp.html
UDP threads are usually good place to start. They give a good general idea/view.
kenc15
Sep 25, 2015 06:38 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
