P0455 cel on.. Please help!
Old Aug 22, 2010 | 07:35 PM
rohanmax14's Avatar
I have 2004 Nissan maxima I recently changed control valve assembly n I clear the code. Next day at night I fillup a little gas before going home. Will after that my cel came back on with same code p0455.
I did not put seal on new control valve assembly.
Anybody?
Thank u.
Old Aug 23, 2010 | 11:43 AM
Apollos2's Avatar
Sounds like that could be it, just don't put too much on.
P0440 - EVAP Control System Small Leak
P0441 - EVAP Control System Incorrect Purge Flow
P0442 - EVAP Control System Small Leak Detected (Negative Pressure)
P0443 - EVAP Canister Purge Volume Control Solenoid Valve Circuit
P0444 - EVAP Canister Purge Volume Control Solenoid Valve Circuit Open
P0445 - EVAP Canister Purge Volume Control Solenoid Valve Circuit Shorted
P0446 - EVAP Canister Vent Control Valve Circuit
P0447 - EVAP Canister Vent Control Valve Circuit Open
P0450 - EVAP Control System Pressure Sensor
P0452 - EVAP Control System Pressure Sensor Low Input
P0453 - EVAP Control System Pressure Sensor High Input
P0455 - EVAP Control System Gross Leak
P0456 - EVAP Emission Control System Very Small Leak (Negative Pressure Check)
Old Mar 3, 2017 | 03:29 PM
santa6's Avatar
Need a little help. My daughter's 2008 Maxima has been throwing this code for a while. We have replaced the fuel cap and the canister vent solenoid valve.
She noticed this hole today. I don't think this is the vent hole, diagrams seem to indicate the vent hole would be lower than this.
Is it the hole where the original gas cap tether was attached? Should it be there at all? It seems to be outside the boundry of the fuel system - could it even cause a code problem?
Thanks for any help.
Old Apr 16, 2017 | 08:50 AM
santa6's Avatar
Any help appreciated on this. CEL is still. I'd like to avoid the dealer and the smoke test.
jmlee44
Oct 2, 2022 02:13 PM
captchaos
Mar 15, 2016 12:18 PM
MaxDD
Sep 24, 2015 06:40 AM
homeofbacon
Sep 23, 2015 07:17 PM
JoshG
51
Sep 21, 2015 10:41 PM
