2004 Maxima Noise need help!
Old Sep 2, 2010 | 07:53 PM
6spdMaxima's Avatar
Hello Guys,
I have 2004 Maxima with 69k miles. It has been making some ticking noise for past 4 weeks. Ticking noise comes from the engine when i turn on the car and its cold. It goes away after few minutes when car warms up or i start driving and i go over 3,000 rpms. Is this something i should be worried about??
Thanks for help in advance.....
Old Sep 3, 2010 | 09:15 AM
6spdMaxima's Avatar
I heard that if i use stainless steel oil filters might make less noise also i was wondering if i do oil change and bump to 10x30 synt..instaed 5x30 would it make any difference? I know its timing belt and does anyone know when should i get this replaced.
Old Sep 3, 2010 | 10:29 AM
21max's Avatar
Your vehicle does not have a timing belt it has a chain!The noise ur talking about is it coming from that area or valve covers,if its coming from the valve cover area i would take an oil pressure test to be safe.If the oil pressure is good i would try a bg flush and change the oil and then see how it sounds after the oil change!
Old Sep 4, 2010 | 08:49 AM
VigilanteMax's Avatar
if oil is good and staying full, then not worrisome VQs tick
Old Sep 4, 2010 | 12:47 PM
1hawaii50's Avatar
My car sounds like a diesel when it is cold. You are approaching that magin mileage number where the timing chain guides are going to need to be replaced.
Hondarydr
Dec 30, 2024 06:15 PM
maxinout93
Oct 27, 2015 01:29 PM
egali045
Aug 16, 2015 01:19 PM
soon2ownmax
Aug 13, 2015 02:19 PM
Tanvirkamal
Aug 5, 2015 01:32 AM
