CAR HEAT
Old Sep 16, 2010 | 06:12 PM
soon2ownmax's Avatar
CAR HEAT
My 2004 Max doesn't heat up while at idle. Works fine when the car is driving or RPM's are up when revved up. Anyone else have this issue before?
Old Sep 16, 2010 | 08:02 PM
DAlastDON's Avatar
Low coolent/air bubble
Old Sep 16, 2010 | 08:20 PM
blackmax85's Avatar
do you hear water rushing underneath the passanger seat? i agree with low coolant/air bubble.
Old Sep 17, 2010 | 04:16 AM
I'll have to take a look and get back to ya guys, but thanks for the advice, hopefully its something as simple as that
Old Sep 17, 2010 | 05:13 AM
21max's Avatar
low coolant or restriction in system...
Old Sep 18, 2010 | 07:16 PM
1hawaii50's Avatar
Have you ever flushed your cooling system? It could be a blocked heater core. I'd start with a good flush. If you go to NAPA, they have a cleaner that you can add to the radiator prior to doing the flush that will help clean it out, I can't think of the name off of the top of my head.
Old Sep 21, 2010 | 11:41 AM
CanadianMoFo's Avatar
This is a fairly common problem. There is a specific TSB out for this.
CM
Old Jan 31, 2011 | 12:37 PM
maxman804's Avatar
I'm having the same problem and I also hear water moving. What should I do
Old Jan 31, 2011 | 01:41 PM
dpeles1's Avatar
Check coolant level. Mine was doing the same. It was low I added coolant. Drove it around. Added some more. Problem solved.
Old Feb 6, 2011 | 06:29 PM
sam05max's Avatar
try checking the thermostat, if it sticks open then u wont have any heating up. EG..upper and lower radiator hose same temp
Old Feb 8, 2011 | 10:51 PM
chris350's Avatar
don't forget to burp the radiator... lol
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
98nismomax
Aug 13, 2015 12:15 PM
acw
Aug 13, 2015 12:50 AM
egali045
Aug 5, 2015 09:02 AM
