Thermal Intake Manifold Spacers
Mod: NWP Engineering Phenolic Thermal Intake Manifold Spacers
Price: $225
Available: at www.nwpengineering.com
Performs: The NWP Engineering Thermal Intake Spacers are made of a high quality durable type of phenolic and prevents heat from transferring to the intake manifold. The intake manifold temperatures decrease by 40 degrees on AVERAGE and the spacers yield an average dyno proven gain of 10hp and 12ft-lbs of torque. Your car will no longer feel sluggish due to heat soak after it warms up!
The kit comes with 5 spacers which include two Lower Intake Manifold Spacers, an Upper Intake Manifold Spacer, an Elbow Spacer, and a Throttle Body Spacer. The kit also includes all the fasteners and hardware needed as well as printed installation instructions.
All spacers are CNC Machined to the highest tolerances and are port matched. Port matched intake spacers is a very important aspect, since the poorly sized OEM intake gaskets are no longer used. This drastically improves airflow over stock! Also, the spacers can be reused as many times as you like since they will not misshape, soften, or warp over time. They will easily outlast the life of your vehicle!
Installation Difficulty: * * (2-3 labor hours)
Links to Existing Threads:
http://forums.maxima.org/showthread.php?t=384774
http://forums.maxima.org/showthread.php?t=387128
http://forums.maxima.org/showthread.php?t=404064
Price: $225
