racingline y pipe help!!
Old Oct 7, 2010 | 03:01 PM
lighty0770's Avatar
so i got my y pipe in today and was ecstatic to install it... only problem is that all 5 bolts i need to take off are so rusty. i took it into a shop to see if they would loosen the bolts for me but they said since the pipe had a cat delete they couldnt take any part in it. does anyone know how i might be able to loosen these bolts myself without the use of a blowtorch (what the shop told me) or any shop that would be able to help me.
i live in frederick maryland but am currently in salisbury md. so pretty much anywhere in md would be awesome!
thanks guys!
Old Oct 7, 2010 | 04:53 PM
HotshotVQ35's Avatar
try soaking the bolts in liquid wrench or wd40, a breaker car can also help
Old Oct 7, 2010 | 05:37 PM
Terrentius's Avatar
Go buy a torch, heat those nuts up, and you will be good to go.
Old Oct 7, 2010 | 08:58 PM
bambino's Avatar
I live in MD (20902 area).. I might be able to help, but to be honest, if you go to any auto parts store, they have the wb 40, but they also have another can. Try that one... if you need help, let me know, I can probably help you, I'm instaling my intake and my exhaust this weekend.
Old Oct 7, 2010 | 09:36 PM
NiZMo1o1's Avatar
soak them in PB Blaster , thats is your best friend, WD does OK
We use PB blaster at the shop for rusted bolts, here is a trick also. once youve soak them.
I belive its a 14mm , you need to loosen it 3 turns, then 3 turns tighten again , as you loosen it , spray./soak some more pb blaster.
You keep turning it 3 times back and fourth , until it feels loose.
We do this if we try to keep the bolt were using, why we do this ?
Because there is threads on both end of the bolt, so the nut needs to be soak, as you turn loose and turn it back, your basically going to heat up the threads, so this way you keep it from stripping, so back and fourth and stop.
if you keep trying to loosen it more than likely the bolt is going to be hot and it will break in half.
If your NOT saving the bolts and plan on installing new metric bolts in there with lock washer, than just break them off.
If your DIY , im sure you want to keep the bolts if they are re-usuable.
again , prepare to get new bolts if its really rusted.
if your patient you can soak pb blaster and loosen the nut slowly.
Old Oct 8, 2010 | 10:33 AM
aznstormin's Avatar
Great info NiZMo. I'm a diy and just got the Racinling y pipe. All I was going to do was to soak it with PB Blaster and try it. If it didn't work, then spray more PB Blaster until I can loosen it.
Old Oct 8, 2010 | 10:39 AM
blaxima06's Avatar
If those don't work, you should probably sell me the ypipe. =)
Old Oct 8, 2010 | 11:24 AM
bambino's Avatar
Actually, I'm closer.. so boo yaa! Jokes aside, Pb blaster was the can I was referring to before, soak it in that and that should do the magic...
Old Oct 9, 2010 | 02:00 PM
Hellrot318is's Avatar
Any exhaust shop would be able to help you. It's easier to get it on a lift and they can torch that off for cheap
Old Oct 9, 2010 | 07:03 PM
akalito's Avatar
yeah same happened to me. jack my car up as soon as i get the ypipe cant get the effin bolts off. i went to a local shop and had them install it. they sprayed it with something let it sit for 5-10mins then use air tools to take it off. like another member said your better off taking it to an exhaust shop an getting it done
Old Oct 19, 2010 | 11:16 PM
lighty0770's Avatar
she went on like a charm
Old Oct 26, 2010 | 07:44 PM
vitec115's Avatar
how about an impact wrench??
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Quickywd01
Sep 21, 2016 09:36 PM
