AC Not working
Old Dec 1, 2010 | 08:30 AM
BETO6700's Avatar
AC Not working
This morning I turned on my AC because my windshield was so foggy from the rain and humidity then I noticed it wasn't blowing cold air. I checked under the hood and saw an AC hose(front of engine) leaking some kind of green fluid.Is AC oil green?
I just recently had some work done at the dealer (replacing motor mounts) and makes me wonder if they disconnected the AC hose in order to install the mounts.
Appreciate any info....
Old Dec 1, 2010 | 09:35 AM
Terrentius's Avatar
Check AC fuses, connectors and hoses.
If you have a leak from any hose, then you should get that sorted out.
Old Dec 1, 2010 | 09:42 AM
KevMaster's Avatar
Please read THIS thread.
forums.maxima.org/6th-generation-maxima-2004-2008/394045-c-leak.html
Copy and paste above link and add "http://" at the front in new browser.
If link does not work then search for "A/C leak" under 6th generation maxima (2004-2008)
Old Dec 1, 2010 | 10:51 AM
geekedout's Avatar
I believe the low pressure hoses are a common problem with our car. I've already replaced mine.
Old Dec 26, 2010 | 06:39 PM
Golfgodjason's Avatar
I had the same problem. Bought the low pressure hose for about $80. Just two screws, one on top and one on bottom, hold it on. It took about 10 minutes to replace including putting it up on ramps to get to bottom screw. Had a friend refill the fluids and it is good to go.
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
Maxima30
Sep 7, 2015 06:13 PM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
