NON HID to HID Headlight Assembly Conversion
I have a 04 se. It didnt come with Stock HIDs so i got a HID fog light kit and and a hid headlight kit. The output is def much better but not as much as i expected as it does not have HID projectors..
I was wondering if i can buy the HID headlight assemblies and put them in my maxima..and then use the hid kits in there.
Please advise..
Please advise..
Not sure....you might have to purchase hood as well to fit new "projector" headlight assembly units...
Anyhoo, there are several who have done it and I am sure will advise when they get the chance.
And yes, the factory HID lamps are plug & play, if you get the 04-06 version for your car. BTW, there is a set for sale currently in the classified section.
Oops, my bad...I was thinking you wanted to put in 07-08 headlamp units. Hence, the talk of hoods and such.
That would great to get in some factory headlamp units for the year of your car.
Good luck.
Good luck.
Thread revival
Are the stock halogen headlight housings the same as the stock HID ones? Asking because i have an 07 with the halogen bulbs and wanted to upgrade to the OEM plug and play HID kit. Was hoping to just be able to get the OEM ballast and bulbs while using my existing housing. Is this possible or will i need to get Nissan HID headlight housings. Thanks in advance.
Yeah, also the lens that is used along with the addition of a ballast. Pretty much the whole thing is different from halogen projectors.
Some people just do a retrofit with E55 projectors so that the cutoff, glare and everything is corrected. They can use 55W HID kits and have the REAL effect that it's supposed to.
Thread revival
I actually have all parts to convert my halogen headlights to OEM HID (including HID harnesses and caps), I just haven't had any free time.
Thanks for all the responses.
Retro seems to be easier said than done and at over $1400 for a new set from the factory i dont see myself buying them anytime soon either. Guess my best bet is to find someone who can do a clean retro and call it a day.
However, if you're serious about getting a retro I'd take a look at hidplanet.com. A lot of good information out there and you can find some top notch retrofitters as well.
Either way be prepared to spend around $800 for the entire thing.
New headlights
bulbs/ballast
projectors
harness
installation itself
You could spend less if you can get good deals on parts and even less if you do it yourself and use your current headlights. Good luck!
The main point is changing the projectors to HID E55 projectors (specifically the Maxima version), which are a DIRECT drop-in replacement of the halogen projectors. They use the same mounts and everything, so it isn't too much of a retrofit. And you don't HAVE to use OEM ballasts and bulbs if you don't want to, it's more of a preference. If you used your own headlights, I would say at most you'd spend $400 (dependent on buying new or used), but you can definitely find deals to spend even less.
You can find the projector on ebay....... http://cgi.ebay.com/ebaymotors/04-05...Q5fAccessories
But you would have to open your headlights and swap the projectors.
You can probably get a better price on the projectors though. I've seen a pair of TSX projectors go for $60 and those are better than what the Maxima has. I've had those TSX ones on my 05 Altima. If you don't mind doing some cutting, something like the TSX should be a pretty easy fit.
Really?
I didn't realize the whole setup is different, i never have seen any docs on this. I think that just the bulbs are different, and the xenon setup just included you p/s.
In my Service manual, the only thing different is the buld and added ballest.
The wiring harness is different. If you look at the sealing caps on a xenon wiring harness and a halogen one, they are different. The xenon harness has different connections on it.
The headlight housing itself is physically SIMILAR to the halogen one, but the xenon one has an opening at the bottom for the ballast, so it is not the same.
The rest of the components are the same, but the headlight assemblies as a whole are definitely different.
I have an 06 maxima that came with the non hid assembly
And I always wondered the same thing
I purchased 2 used oem hid headlight assemblies off of ebay for 250 ea.
And they plugged in with no modifactions
In fact they have been in working for 2 yrs with no problems
The projector inside is different. A halogen projector will not accept a xenon D2S bulb, nor is it built to properly direct light from a xenon bulb (even 9006 HID kits).
I gotta include that for the 6.5's. The Halogen headlights are sealed and the HID headlights technically are not (because it has to let air in for ventilation in order to prevent the housing from getting to hot). Which is why there's a TSB for condensation on HID headlights for the 6.5 gens.
Nope, those are aftermarket headlights that aren't made with the same type of materials. Basically lacking a lot of quality. Also, for genuine HID headlights. They would be 1500+ for a pair.
EDIT:
Here's a link for just one headlight:
http://www.courtesyparts.com/26060-l...669_2705_2712&
EDIT:
The used OEM HID headlights I purchased off of ebay, were not perfect. One assembly had one bracket out of the four missing. But it installed with no problems and remained secure. I think they were salvaged from crashed vehicles. They worked fine for me for 2 yrs, then one of the bulbs started going pink, so I decided to change both bulbs to phillips ultinon 6000k, and now they look really good. I think the hardest part about changing the assemblies is taking off the bumper to get to them, because the assemblies just plug right in. Just like the halogen assemblies. Nothing different. But after taking the bumper off a few times it gets really easy. It only takes me 10 mins now to remove the bumper.
I initially tried changing the bulbs in my original halogen assemblies with those 9006 hid kits that you see for sell, and they were just a pain for me IMO. I had so many issues with condensation filling up the assemblies, and I just could never get it right. Plus you have to line up the ballast somewhere that is secure. After purchasing the used OEM assembly I wished I would have just done that initially. The ballast is already attached to the assembly underneath, so there is no guess work as to where to mount it. Or no additional cables to run.
doctorpullit
Oct 28, 2019 10:58 PM
Calabar
Oct 5, 2015 09:57 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
atriuum
Sep 28, 2015 01:19 PM
