Deus joins the Dub Club!!
Old 01-16-2011, 09:33 PM
DeusExMaxima's Avatar
I have always thought 20's looked great on the Maxima but I didnt like that it affected performance. 20's are heavier than 18's - all else being equal - and I have geared my car towards performance since I track it. However, I dont track it very often. My street/race tires (Falken Azenis) are wearing out and I needed to raise my car a little to clear my "new" RLM bumper.
Sooooooo . . . I decided to go for 20" rims. I have always loved my black and red theme so i needed rims that were black with a red stripe. I thought about buying black rims and striping them myself. I considered carbon fiber rims (the fake ones, not the real CF 5,000 dollar rims). I decided on Gino model 493 rims in a 20x8.5 with 35mm offset and 255 35 20 tires. They are heavy as hell compared to my light 18s. I needed 10mm spacers for the fronts to clear the 300ZX TT calipers. I got some hubcentric 10mm spacers and longer studs. I put some cheapy 5mm spacers on the rear but Im going to remove those.
Anyhow, here they are:
Let me know what you think.
DeusExMaxima is offline
Old 01-16-2011, 09:35 PM
The old 18" rims:
Old 01-16-2011, 09:37 PM
dstruc's Avatar
damn. those wheels look sick.
dstruc is offline
Old 01-16-2011, 10:03 PM
hero782's Avatar
looks great!! i actually had 20's but switch to 19's
hero782 is offline
Old 01-17-2011, 06:24 AM
Shift_Max's Avatar
Sorry but not I am not fan.
Shift_Max is offline
Old 01-17-2011, 06:53 AM
iMaxSE's Avatar
They look good Deus................nice!!!!!!!!!
iMaxSE is offline
Old 01-17-2011, 10:56 AM
HMAX08's Avatar
I like the black with the red, goes well with the car but i am not a bigg fan on the design of the wheels. I would of liked to see your car with a staggered set up? Thats just my opinion only. Other than that car is a beast
HMAX08 is offline
Old 01-17-2011, 12:00 PM
*moderator*
jsmithsole's Avatar
Looks good but i would have thought you would of went with something a bit more "racy" looking, like these maybe...
Either way, welcome to the 20 club!
jsmithsole is offline
Old 01-17-2011, 01:17 PM
Ah, I was curious as to your opinion J. I dont like the full red lip on those rims. I have seen them on a Maxima and its a bit too much red. I prefer to thinner red stripe on only the outside of the rim. I was getting some rubbing in the rear so I removed my 5mm spacer back there. Ill drive it and see how it is. Tire size is 255 35 20 and rim is 35mm offset
Old 01-17-2011, 02:18 PM
They look much better compared to your 18's.
ChrisMan287 is offline
Old 01-17-2011, 04:22 PM
SuPeRmOd
NismoMax80's Avatar
Hey D, confused why you keep saying the 20's raise the car? my bumper hits just as much with either of my 2 sets of 20s or my stocks. the center of the wheel is the exact same with proper tires keeping the same overall circumference, radius, and diameter.
Regardless looks nice! just don't park too close to me haha.
NismoMax80 is offline
Old 01-17-2011, 04:52 PM
SmokinMaxSE
SmokinMaxSE's Avatar
Looks Hot !!! Don't let anyone tell you otherwise.
SmokinMaxSE is offline
Old 01-17-2011, 05:01 PM
Rods03Max619's Avatar
I guess he meant "Sorry but no, I'm not a Fan" but me they look good and goes with the ride!!
Rods03Max619 is offline
Old 01-17-2011, 06:25 PM
Sorry for not clarifying. The 20's are 2 inches in diameter larger than the 18s but the sidewall height is lower on the 20s. Simply because you get 20s doesnt mean the car will raise up from 18s. Here is my situation. My 18 inch tires were 255 40 18 which yield a diameter of 26.03 inches. The 20s are 27.02 inches. The ride height difference is half the difference of the two numbers which comes to 1/2" higher. The stock tires had a diameter of 26.68 inches. So these tires I have now are 1/4 inch higher than even the stock tires. A larger tire can mean more mass for the car to push. However, you engine turns slower and a given speed since the tires are larger. By the way, that 1/2 inch makes a BIG difference when you are going in and out of driveways. You still have to be very careful.
Check out this excellent tire size calculator: http://www.1010tires.com/TireSizeCal...bmit&reset=yes
Old 01-17-2011, 06:38 PM
SuPeRmOd
NismoMax80's Avatar
haha ok, i assume you kept closer to oem specs. yeah i had the calculator as a sticky before someone moved it.
Old 01-18-2011, 09:25 AM
KC's FINEST
KCMAXX's Avatar
Are there really JDM stickers on your car?
KCMAXX is offline
Old 01-18-2011, 02:01 PM
There is a company I have dealt with, that has the initials JDM in the name. I can remove it if you would like
Old 01-18-2011, 02:13 PM
HotshotVQ35's Avatar
makes the brakes look soooo small now
HotshotVQ35 is offline
Old 01-19-2011, 09:34 AM
It does make them look smaller. It also makes them more visible and improves air circulation to keep them cooler
Old 01-19-2011, 02:57 PM
My axles cry for mercy...
essential1's Avatar
6th gens can definately pull off larger diameter wheels no problem with the correct stance. And I love seeing a well done 6th gen with larger wheels. But IMO, your car flowed better with the 18s. I think its just the design of the 20s you chose that throws it off for me. It has sort of a (dont take this the wrong way) soft look to them when bolted to your 6th gen. While the rest of the car has an agressive approach, as you pan down to the wheels, it throws that whole balance off for me.
But above all that, I understand and respect that your choice for wheels goes beyond just aesthetics. You achieved your goal of raising the car a little to be more careful with the bumper. And as long as you are happy with the end result, congrats and dont let anyone elses opinion sway your own personal opinion. It obviously hasn't so far which enabled you to have a truly unique and impressive maxima. Keep moding!
essential1 is offline
Old 01-19-2011, 03:00 PM
choiiiiiiiiiii's Avatar
ew
choiiiiiiiiiii is offline
Old 01-19-2011, 06:47 PM
I appreciate the thoughtful opinion. Its very hard to find black and red stripe rims in 20s and it took a while. They look better in person as the finish is not apparent in pics.
Old 01-20-2011, 10:51 AM
6.5affiliate's Avatar
VERY NICE RIMS!!!!!!!
6.5affiliate is offline
Old 01-20-2011, 11:29 AM
MIKERNM1990's Avatar
Good Job Man! Also I like red stripe wheel!
MIKERNM1990 is offline
Old 01-20-2011, 06:56 PM
This Space for Rent
Domestic Violence's Avatar
Those stickers gotta go
Domestic Violence is offline
Old 01-20-2011, 07:22 PM
likwidsilvur82's Avatar
I read through the whole thread and didn't see anything about the weight of the wheels and tires. Dues, have you weighed them and made comparison against your previous wheels. Do they feel any heavier?
likwidsilvur82 is offline
Old 01-20-2011, 09:14 PM
I purposely ignored the weight since these are street only wheels. They are VERY heavy compared to my light 18s. I kept the 18s for track use.
Here are more pics:
Old 01-21-2011, 01:45 AM
Forgot to mention that the RLM bumper looks AWESOME. You did a great job on that....you have any pics with the cornering lights on?
Old 01-21-2011, 11:05 AM
Thanks!! The wiring to the cornering lights don't seem to have juice. I have my equipment ready to go this weekend to diagnose the problem - power tester and volt meter. When I get them going, I will probably make a new thread regarding LED cornering lights. Keep your fingers crossed.
Old 01-21-2011, 07:55 PM
No problem, definitely looking forward to seeing the new thread! Hopefully you can find enough voltage for them. If the old cornering light connections are dull than maybe you can splice them to the fogs
Old 03-04-2011, 12:52 PM
More pics:
Old 03-04-2011, 01:15 PM
rock_drummer's Avatar
very niceeeeee
rock_drummer is offline
Old 03-04-2011, 01:18 PM
how bout a pic where you can see the rims AND the new hood overlays?
Old 03-04-2011, 02:53 PM
nunumkv's Avatar
lookss nice lower it?
nunumkv is offline
Old 03-04-2011, 04:35 PM
Its been on Progress springs for many years
Old 03-04-2011, 04:43 PM
Hows this:
Here is a rear view:
Old 03-05-2011, 06:05 AM
Staggered357's Avatar
Deus those look sick, I am glad you mad ethe jump, I know it's a weight sacrifice but she looks so much better to me I love it...
Staggered357 is offline
Old 03-05-2011, 10:22 AM
chulo's Avatar
looking good bro!
chulo is offline
Old 03-05-2011, 10:23 PM
Originally Posted by chulo
looking good bro!
Dang chulo!! Is that my car?? Nice job on the pic. Can I keep it?
Old 03-06-2011, 10:43 PM
chulo's Avatar
of course
chulo is offline
Quick Reply: Deus joins the Dub Club!!
