Tail light replacement
Old Jan 28, 2011 | 03:16 AM
Torchcorvette's Avatar
The upper rear bulb is out and needs to be replaced on the 2007 Maxima. I noticed that there are two circular plastic devices holding the trunk trim in place.
Before I break them, does anybody know how to properly remove and replace them.???
Thanks in advance for any info.
Old Jan 28, 2011 | 04:32 AM
Terrentius's Avatar
Make sure you have your bulb first. I ended up going to the dealership to buy it after two bulb purchases previosuly failed to provide me with the correct bulb even though the serial numbers matched....
With a flat-head screw driver. Get in there and see how the parts move. Do this is warm weather, or in a warm garage. Plastic gets quite brittle when it is cold. Once they are out, pull back the trunk-trim and you will see the two nuts holding the tail-light assembly to the car. Take them off. Now, some guys tape around the body of the tail-light assembly, especially at the bottom, so when you gently rock it out it the assembly does not scratch the paint. It is held in place with rubber-stabilizer plugs, the same way the air-box is held in the engine bay. So, a little effort, rocking, is required to get it out
Other than that...too simple.
Old Jan 28, 2011 | 03:11 PM
jsmithsole's Avatar
*moderator*
Once you get in there...
Old Jan 30, 2011 | 01:49 PM
Thanks for the info. I stopped in the local independent Nissan shop and the tech there changed it in about 3 minutes. Shop owner wouldnt take my money.
Between watching the tech and the replies above, I'll know how to do the right side bulb when it fails.
Thanks.
vingodine
45
May 21, 2016 12:46 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
220k+ A32
Aug 17, 2015 03:57 PM
Balkins
Aug 12, 2015 06:39 AM
