No sound from aftermarket stereo
I attempted to install my Pioneer head unit in my 04 last night, but ended up with no sound. I tried 2 different wire harnesses - 1 Metra that said it was for amp intergration that had the speaker wires connected to RCA plugs to plug into the back of the head unit, the other without the RCAs just wiring green to green, purple to purple and so on. No matter what I tried, I got no sound. I have the factory Bose system with CD and tape player. Anyone have this problem before? Anyone know of a different/better wire harness I need to be using? I was going to cut the plugs off of the car harness and attempt to wire the speakers that way but I couldn't figure out which were the speakers wires. PLEASE HELP!
Maybe I connected the wrong one. The head unit has a blue/white wire that says something about remote power, or something to that effect that I connected to a blue on the wiring harness. But now that I think about it, there may be another solid blue wire on the head unit. Would that be the correct one?
Did you properly ground the unit? There is a black wire ( I beleive it is black, correct if wrong) that needs to connect to chassis. best location to ground that wire is upper left screw that holds radio/display combination metal frame in place.
As of power control, yes, it is usually blue/white wire coming from the unit. Where exactly it is supposed to go? Check FSM diagram for your particular application, there is a separate page for models with Bose, find the right connector and pin# and get it done. I beleive it is pin#5 for connector M43 plus M44 for the radio. And pin#31 for connector B127 plus B128 for Bose amp.
Alright, here's what I've finally figured out - from the factory side of the wire harness, the blue/white and the blue wires BOTH have to be connected to the blue/white wire coming from the aftermarket stereo. Also, the antenna has to be connected to the deck before it will come on. I guess it sort of acts like a ground, although not the only ground.
As stated above, connect all 3 blues together. The reason you have to make a seperate ground when installing an aftermarket is because the ground doesn't exist in the factory wiring harness. The 4 screws that hold the factory radio in are the actual ground. Get it figured out?
This doesn't sound like it's related to a loose connection. I haven't pulled anything apart to look cause I'm not exactly sure where to start!
It could be a loose connection at the speaker itself or the speaker grounding out. I have a bad connection on my factory Bose in my Yukon and the front driver's cuts out a lot and if I open and slam my door shut, it comes back on. It's more than likely the connection at the speaker or it grounding out. That is, if everything behind the dash is good.
make sure you connec the remote wire from the HU harnes to the blue wire that goes in the non rca harnes. i tried the amp integration one but dint work and i just installed the regular harnes and i made sure i hooked up the remote cable and it worked perfectly and sounds great. but this was on my 03 it should prob work the same
im finding it impossible to find help with posting restrictions on every forum and not enough info for my car. i have a 2004 maxima without bose. but on the rear deck there is a small amp i think between the two subs. i already got a metra dash kit and a wire harness and a antenna adaptor. i really want to install this myself but the only thing holding me back is how to wire the sony stereo wire harness to the metra harness and where to ground wires and is the factory non bose amplifier the same thing as a bose ampilifier because i got the Metra 70-7550 wire harness , 40-NI10 Nissan Antenna Adapter PLEASE HELP ME i dont know what to do with the black wire on the metra harness... my stereo has a black ground wire which i will screw in some where to ground it... but what do i do with the metra black ground wire? and im confused about the blue wire i dont have bose so do i join them together or just connect the blue with blue and blue white with blue white?
Yeah, I got everything figured out. But now I'm having a new issue. If I hit a bump while driving, the speakers on the left side go out. Sometimes they will come back on after I hit another bump. Sounds like a loose connection, right? Well check this out - while they (left side) are out, if I crank the stereo up pretty loud, they come back on.
This doesn't sound like it's related to a loose connection. I haven't pulled anything apart to look cause I'm not exactly sure where to start!How did you fix everything I installed a new aftermarket radio everything look fine, it turn on and work properly but i have no sound.
