radiator fan
Old Mar 13, 2011 | 07:07 AM
cspangg's Avatar
radiator fan
fans are intermittent, if i spin the fan with my hand, it starts working or tap on the back of the motor. Both fans are doing the same thing with a/c on or not.
Old Mar 13, 2011 | 12:50 PM
twentyeggs's Avatar
Check the connection. It may be that the wire supplying the power to your fans is lose and its not getting the full current. It also sounds like your motors are going out. the only thing that shys me away from that is you say its happening to both your fans and the odds of both fans going out at the same time are unusual. usually when a fan needs to be helped along before it works, it means the bushing are burnt out and the magnetism going on in there is not efficient. what i would do is cut the wires and hook them directly up to the battery to rule out that the motors are going out. if they start without help then its your connection. (i have never looked at the fans in our car and i would be very surprised if they needed anything less than 12 volts to operate but check first to make sure the current isn't too strong for a direct hook up, if it were me i wouldn't be concerned, just don't sit there with the fans on the battery for a long time. the rule of thumb is you can safely run 1.5 times the recommended volts on an appliance, and 2 times the volts safely for short periods of time. the reason i wouldn't even check is because it is extremely unlikely they fans were built to run at anything under 6 volts, that's retarded.
Old Mar 13, 2011 | 05:46 PM
cspangg's Avatar
Thanks, I'll let you know what happen.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
RWCreative
Sep 21, 2015 11:01 AM
