Coilover seized!
Old Mar 17, 2011 | 07:50 PM
rohanmax14's Avatar
Coilover seized!
I have BC racing coilover. I was going to reset preload, but when I put spanner on the 1st top ring where we turn right to rasine up preload is won't Move. This is only driver side issue. How u guys do it? Thismy first coilover, so be with me lol.
Old Mar 17, 2011 | 11:18 PM
WD40 or PB Blaster!
Old Mar 18, 2011 | 04:22 AM
phatboislim's Avatar
first make sure you clean the threads on the coilover, then shoot it with PB blaster
Old Mar 18, 2011 | 07:15 AM
99greddymax's Avatar
once you clean the threads, tap the locking collars with a soft hammer. That helped on my set.
Old Mar 18, 2011 | 09:02 AM
ampire's Avatar
PB blaster and a mallet, tap the spanner.
Old Mar 28, 2011 | 06:39 PM
rohanmax14's Avatar
Sorry guys I'm still having hard time making the top lock move, it barley move not like spin easier like 2nd lock ring spin easy. Supid question does wheel have to be taken off the car?
Old Mar 28, 2011 | 08:39 PM
Matt93SE's Avatar
STFU n00b!
It definitely helps to pull the wheel.
clean the threads off and hose them down with penetrating oil.
stick the wrench on there and smack the wrench with a rubber mallet.
make sure you're turning it the right direction.
once you get it loose, coat the threads liberally with anti-sieze before putting it all back together.
..... moving to 6th gen since this is not advanced suspension.. pretty basic maintenance ish here.
Old Mar 29, 2011 | 04:56 AM
this is fukin sig worthy
Old Mar 29, 2011 | 05:27 AM
I3LAZEN's Avatar
You can also use a air chisle and hit it real quick and you should be able to get it unseized... works for me.
Old Mar 29, 2011 | 05:36 AM
i clean my threads with a wire brush, then spray it with a white lithium spray grease. i've only loosened them once, but that one time, seemed really easy since using that spray grease...and i always run the locking collar all the way to the bottom and then back up so that grease will be well spread. then i spray it once more after i lock everything back down
Old Apr 29, 2011 | 09:50 PM
rohanmax14's Avatar
Update: I hit it with rubber hammer when doing reseting preload on driver side n I didn't reset preload on passenger side bec spring was tight. Then 2 days later is started to make knocking noise on both side when turning left/right. Damper nut is tight.
Can someone tell me somethings?
BkGreen97
Apr 2, 2016 05:47 AM
NewMax03
Oct 7, 2015 08:27 AM
NismoMaxi02
Oct 4, 2015 09:09 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Garrettz459
Sep 28, 2015 02:50 PM
