Passenger side
Old Mar 29, 2011 | 08:47 AM
Veniality's Avatar
Passenger side
Hi Guys,
Just find out that the carpet on the passenger side is soaking wet.
i dont know where it came from...... does anybody experience this kind of problem.... pls, chime in..
thanks really appreciate
Old Mar 29, 2011 | 09:13 AM
officerfrasher's Avatar
1. If the water only shows up when you run the AC, it's probably the AC condensate drain
2. If the water shows up when you run your heater it's probably a leak in the heater core.
Old Mar 29, 2011 | 09:14 AM
MadMax07SL's Avatar
Heater core is on the pass side under the dash...could be a leak there or at the heater hoses coming into the firewall. Or perhaps your condensation line for the moisture from the evaporator is stopped up or missing. I've seen on other cars where the condensation hose under the hood up against the firewall was missing, and the water would trickle back inside the firewall instead of falling to the ground through the small hose.
I say all this with knowledge from other cars, not the Max directly. But those are things I'd think could cause it. Of course a bad seal on the door could allow water in as well...
Dennis Twohy
Oct 1, 2015 06:01 PM
lkiller123
Sep 21, 2015 03:00 AM
Bonka
Sep 14, 2015 11:18 PM
Colossus
Sep 9, 2015 05:46 AM
FanaticMadMax
Sep 4, 2015 02:45 PM
