AC/Heater Problems
Old Apr 5, 2011 | 07:55 PM
Sinister-13's Avatar
AC/Heater Problems
Was hoping someone could help me out with a recent issue I'm having with my 06 Max. Over the last couple of months, the heater has stopped blowing hot air. Even on the highest setting it will only blow luke warm and will not warm up the inside cabin properly. I also noticed that the air conditioning will not blow cold air. I'm not sure why this has happened all of the sudden. All of the heater/AC controls seems to be working properly.
Any help would be greatly appreciated.
Thanks in advance.
Old Apr 5, 2011 | 08:20 PM
officerfrasher's Avatar
Thanks in advance.
The heater problem sounds to me (feel free to correct me if I'm wrong) like a bad thermostat.
Regarding the AC, have you ever had it charged? If not, it may just be time for a recharge.
Old Apr 5, 2011 | 08:28 PM
No. I have not had the AC charged since I have owned it. I bought the car approximately a year ago. It has 67k on it now.
Old Apr 6, 2011 | 06:20 PM
Any other thoughts? Anyone else have a similar problem?
Old Apr 6, 2011 | 10:12 PM
maxlk's Avatar
might be thermostat since no heat and a/c, but remember the orginal a/c low pressure hose is prone to leak. I just replaced mine and still need to recharge it.
Old May 17, 2011 | 03:26 PM
82AprilFool's Avatar
I have an '06 with the same issues. The heater won't blow hot air unless I'm driving. When my car is idle, the heater blows cool air even at the highest temp. My air conditioner blows hot air even at the lowest temp no matter if I'm driving or not. My air conditioning problem is a cracked A/C hose. I totally forgot to tell the dealership about the heater problem. Your best bet is to take it to the dealship and have it diagnosed. It can be something simple like you may just need Freon to, like my car, the hose may be cracked and needs to be replaced.
Old May 28, 2011 | 03:19 PM
MaxPrime's Avatar
Yeah i just came from my mechanic and he hook it up to a machine and it fail me it said i have a lick , so take it to a good mechanic and tell then to hook it up to the machine and check for a lick , then fill it up with freon and see where is coming out from and then replace the part.
Old May 28, 2011 | 10:24 PM
broknindarkagain's Avatar
I've disconnected the heater core on cars in the past and blew compressed air through it. They get clogged up sometimes. Also, look into flushing your coolant and changing the thermostat
Old May 29, 2011 | 06:40 AM
MaxPrime's Avatar
This is what you do you right but only if you dont have a leak, cause if you do have a leak you will change that and all you need it done was the hose so check with your mechanic to see if you have a leak with that big machine they have and go from there, if is no leak then you check radiator if that is good change thermostat but only if there is no leak good luck.
Old May 29, 2011 | 11:29 AM
KevMaster's Avatar
lick = leak
Old May 29, 2011 | 01:14 PM
po8pimp's Avatar
you might have air in your coolant. Park on an inclined driveway with the nose of the car facing up. With the engine cool, remove the coolant cap. Do not take it off, just loosen. Start your car and turn your heat up full bore. Watch the cap to make sure you are not spewing coolant all over. Once the heat starts to come out very hot, then shut the car off. If this doesn't happen before the car is at normal operating temp, then it is surely your thermostat. Sometimes, it can be the flap that changes from the air conditioning to the heat that gets stuck half way. Not very often, but can happen. It sounds to me more likely an air bubble in the coolant. good luck. if you loose some coolant, just top it off with some water.
Old May 29, 2011 | 05:43 PM
MaxPrime's Avatar
^^^^^^ Nice didn't know that one.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
