Help with wheel offset
Old May 19, 2011 | 04:28 PM
KY3POINT5's Avatar
I am looking to buy some new wheels, but I am not very good with widths, offsets, what works and what doesn't.
I am looking at these wheels: http://cgi.ebay.com/ebaymotors/20-AC...item35a1322ea6
Specs:
20 x 8.5 +20
20 x 10 +25
I could use some advice on tire size as well. I also plan to lower on coil overs for a nice tuck and I am not opposed to using spacers.
Thank you in advance.
Old May 19, 2011 | 05:26 PM
Cali_Swagg28's Avatar
A negative offset means the true centerline of the wheel is in front of the mounting surface of the wheel. This would make the wheel/tire assembly stick out away from the vehicle. A positive offset means that the true centerline of the wheel is behind the mounting surface, thus putting the wheel/tire assembly deeper into the fender well.
Old May 19, 2011 | 05:30 PM
mrkhone's Avatar
i wonder about this setup also. been thinking about buying it with the same specs
Old May 19, 2011 | 06:59 PM
KCMAXX's Avatar
KC's FINEST
http://forums.maxima.org/wheels-tire...-genovese.html
I got what you need...
Old May 19, 2011 | 07:43 PM
officerfrasher's Avatar
Originally Posted by KCMAXX
Trying to ship another set to KY, are ya?!
Old May 19, 2011 | 10:19 PM
joecurr's Avatar
Specs:
20 x 8.5 +20
20 x 10 +25
Are you trying to tuck wheel or tire? Are you opposed to running stretched tires? 20x10 +25 is pretty aggressive, you'd definitely have to run stretched tires, 255/35/20 or maybe even 245/35/20.
Old May 20, 2011 | 01:23 PM
streetsynner's Avatar
No real advise for ya, but I think they will look great!
Old May 20, 2011 | 06:00 PM
twentyeggs's Avatar
25 mm will rub in the back if you have stock suspension stock wheels. 20mm in the front should be fine. to fix the problem with the 25mm spacers, you need to roll your fenders. there are many people who will do it for 50 bucks. just make sure they use a heat gun to make the paint malleable.
if you have lowered your car at all, kiss the 25mm goodby.
Old May 21, 2011 | 08:28 AM
NismoMax80's Avatar
SuPeRmOd
yeah 25mm with my 8" wide 20s rubbed bad in the rear and time i hit a bump or had passengers. stiffer shocks helped very little, rolling the fenders only cracked the paint leading to rust, doubt he used heat like i asked...
25mm AND 10" wide? sure you will rub like crazy.
Old May 21, 2011 | 08:58 AM
Staggered357's Avatar
for the rear you want at least a 35mm..i have 20x10 in the rear with a 41mm off set and i have no problems running a 275/30/20 tire in the rear... easy way to remember..the lower the off set the further out it will sit..thus a skinnier tire...i think..it confuses me sometimes too..but that has been the pattern i have noticed....
Old May 25, 2011 | 02:29 PM
blackmax6thgen's Avatar
that is one aggressive offset theres a guy here with a 10.5 inch rim and a 30mm offset and he made it work his car looks sickkk too.
Old May 26, 2011 | 05:11 PM
joecurr's Avatar
I gotta see it to believe it... lol.
Old May 27, 2011 | 11:52 PM
mr.jame's Avatar
rim look sick. Tire size in the front 245/35/20 and rear 275/30/20 most popular tire size for 20" and the offset sure be ok
Old May 30, 2011 | 09:09 PM
check out his profile joecurr. he also posted on this thread he has a silver Max.
Old Jun 1, 2011 | 01:17 PM
KCMAXX's Avatar
KC's FINEST
Old Jun 5, 2011 | 07:01 AM
MWiebs's Avatar
350Z Wheels
Need some help as well.. Just bought a set of 350Z 17" wheels for my 04' Maxima and the back wheels do not seem to fit correctly. The lug nuts come a little loose after a while and now I have noticed my drivers side back wheel is wobbling so the car is sitting in the garage till I can figure how to fix this. Is there something special I need to get the wheel to fit correctly? It's as if the center hole is not big enough?
Old Aug 21, 2011 | 08:27 PM
woahnicesn's Avatar
Whats your wheels setup? Exactly what im looking to get for my black 6th gen
HOKUSMAX
Nov 13, 2017 04:34 AM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Andy29
Sep 29, 2015 05:32 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Redfox
Sep 28, 2015 10:41 AM
