P1283, source?
Old Jun 25, 2011 | 09:00 AM
drose's Avatar
P1283, source?
A few weeks ago I got the service engine light and pulled the code being P1283. It just so happened that I was getting the oil changed the next day and while the car was hoisted, it was noticed my flex pipes were done for and leaking.
I had the flex pipes replaced and within 10 kms the service engine light went out. The light stayed out for about 2 weeks and has come back on this week.
When the light comes on, I can clear it with my diagnostic tool, and then I could drive the car all day without the light coming back on as long as I didn't shut off the car. If I shut off the car, within a few miles after starting it again, the car will throw the P1283 code.
I took it to a different muffler shop to see if maybe there was another leak ( didn't want to take it to the place where I got the flex pipes as they may try to deny they screwed up the job ). I'm told there are no leaks, so now I am left to wonder what the next step is diagnosing this is.
It does mention air/fuel in the diagnostic tool, so I'm assuming O2 sensor, but which one?
Anyone ever have this code and found a fix?
Old Jun 26, 2011 | 06:11 AM
Costee's Avatar
Here's a TSB on the code:
MUST CLEAR SELF-LEARNING AFTER REPAIRING DTC P1273/P1283 OR P1274/P1284 AIR FUEL LEAN OR RICH SHIFT
APPLIED VEHICLES: All Nissan’s with DTC’s P1273 / P1274 / P1283 / P1284
IF YOU CONFIRM:
A MIL “ON” with any of the following DTC(s) stored:
• P1273 / P1283 (A/F Sensor Bank-1 / 2 —Lean Monitor)
• P1274 / P1284 (A/F Sensor Bank-1 / 2 —Rich Monitor)
ACTIONS:
1. Repair the vehicle as necessary.
• Refer to ASIST for diagnostic and repair information.
2. Clear the engine ECU Self-Learning.
IMPORTANT: If Self-Learning Is Not Cleared:
• The DTC may be stored again; even if no malfunction exists.
• This could result in the customer returning with the same incident (“come-back” repair).
Perhaps all you need is to "Clear the engine ECU Self-Learning."
Old Jun 27, 2011 | 08:45 AM
drose's Avatar
Thank you for the info Costee. Any idea how one goes about doing this? Is it just a matter of unhooking the battery for a time period, or is this something the dealer has to do for you?
Old Jun 27, 2011 | 01:38 PM
Costee's Avatar
The service manual suggests the dealer, with the Nissan scan tool called Consult II.
Old Jul 27, 2012 | 06:49 AM
smokin5s's Avatar
is there a way to do this without going to the dealer?
aw11power
Oct 10, 2021 04:57 AM
conansriver
Sep 11, 2015 10:26 AM
Hdnseek
Sep 9, 2015 05:55 AM
TheMafia
Sep 4, 2015 08:26 AM
