Powerwashed calipers using the washing port nipple and i got no brakes now?
Old Aug 7, 2011 | 07:18 PM
Kryogen's Avatar
Yesterday I wanted to clean my brakes real good, so I asked a dude I know and he said use a presure washer on the brakes man with some soap. I saw the presure washing nipple on the top of the brake so I unscrewed it and fit the presuer washer to the port using a custom fitting and blasted the **** out of it lol.
Problem is I heard a loud pop man and I opened the hood and now theres like oil all over and paint is like eaten man and my brakes dont seem to work well anymore? Its like they brake but they brake like a sponge lol, and if I brake too much then they dont brake anymore well.
Did I screw something? I dont understand cause I used hot water with soap and stuff and everything, and made sure I closed the washing port after lol not like I let it open or anything....
asked friend he said man its your brake fluid man, where do I put the brake fluid ???
(Guys, it's a joke, was too funny not to write it. Grats for those who figured I used the bleeder screw and master cylinder cap popped)
Old Aug 7, 2011 | 07:29 PM
revvinMAXto11's Avatar
MAN!!!
Old Aug 7, 2011 | 07:38 PM
HMAX08's Avatar
you fudged something up real BADDDDDDD, I dont understand where exactly you hooked up the pressure washer too, are you talking about the bleeding nipple?? not to be an Ahole, but this just might be epic fail of the year. i sure hope you figure it out ASAP
Old Aug 7, 2011 | 07:56 PM
RAZ76's Avatar
You're a freaking Idiot.
Old Aug 7, 2011 | 08:21 PM
NiZMo1o1's Avatar
wait let me try to understand what you did..
you use a pressure washer , and attached it to the bleeder valve of the caliper ?
im not sure if thats what im understanding from your post but ummmmmmmmmmm
No thats very foooooking BAD ! water and brake fluid does not mix.
you dont EVER apply back pressure back into the brake lines ( I still dont know if this is what you did but it sounds like it )
either that or the pressure washer got water inside the piston caliper.
either way it sounds like you need to bleed the brakes now.
what did you try to do ? or your intention ? clean the caliper ?
Old Aug 7, 2011 | 09:48 PM
DAlastDON's Avatar
That was not a wash port on the brake caliper. That was the bleeder valve that was intended to allow air to escape the brake lines when bleeding the brakes. Get the car in a shop and tell them what happened ASAP. They probably wont laugh until after you leave.
Old Aug 7, 2011 | 09:54 PM
2 GO B4's Avatar
.....sounds like you tried to power wash the braking system entirely.....and I hate to say it...but....you might have jacked up your master cylinder!!! Dude......umm......nevermind...I will just keep any further thoughts to myself.....good luck!
Oh and.....
Old Aug 7, 2011 | 10:23 PM
Nassin's Avatar
just make sure you dont mix any brake fluid with your blinker fluid
Old Aug 7, 2011 | 10:29 PM
BOOTZ's Avatar
Old Aug 7, 2011 | 10:38 PM
QT1 5MT AE's Avatar
Gram Lights addict
this is one of those threads that will go international in minutes. mods should delete this before a guest links this to another forum and the maxima commnity is forever labeled as a bunch of tards
Old Aug 7, 2011 | 10:57 PM
Mr. Blue Sky's Avatar
^^^+1
we don't want this to spread like the NOS energy drink motorcycle incident, or the many other dumb auto related posts out in the internet
Old Aug 7, 2011 | 11:12 PM
STARR's Avatar
When you pressure wash you point and shoot, connecting the 2 ends with a homemade fitting, the weakest link popped hence your noise, is the cap still on the brake fluid reservoir, check the hose that runs off the reservoir, maybe that popped.
Brake fluid when spilled on paint will eat the paint and continue into the sheet metal, you need to sand it to stop it.
Yeah you screwed something up, I say take it to a dealer or brake specialist and see what replacement parts cost, maybe do a BBK.
Your spongy soft brakes is your secondary cylinder kicking in cause the Master was killed, its fail safe to stop the car.
Lastly is this a joke
Old Aug 7, 2011 | 11:36 PM
036mtmax's Avatar
Is this guy plugged in wtf is going on here.Blew the brake res cap off and shot brake fluid all over the engine ?? i thought i heard it all until now holly ****.Some people should stick to pushing a pencil and leave there car alone.
Old Aug 7, 2011 | 11:56 PM
NiZMo1o1's Avatar
yeah sounds like he pressure wash the bleeder valve, push the air/fluids right back out of the brake master.... his only hope is to use the bleeder kit that sucks the whole system out...
At this point its already happen and OP can do nothing about it now but to fix the issue , look back at this as a learning point and laugh about it ( laugh deeply but inside )
it happens , maybe if there was a bit more guidence this wouldnt have happen.
Old Aug 8, 2011 | 12:33 AM
95Maxed's Avatar
I dont think this is bad enough to over take the "Port and Polish my Audi A4 by hooking a bag of sand up to my intake thread...."
But really? A pressure washer... INTO the brakes?
Old Aug 8, 2011 | 12:39 AM
036mtmax's Avatar
:matt93se:
Old Aug 8, 2011 | 03:34 AM
Kryogen's Avatar
Lol thats really funny man I should try the sand too.
You guys know im kidding right?
Old Aug 8, 2011 | 06:47 AM
95Maxed's Avatar
Do we? Do we.....?
Old Aug 8, 2011 | 06:59 AM
phatboislim's Avatar
Old Aug 8, 2011 | 08:21 AM
HMAX08's Avatar
SO WAS THIS A TROLL POST???, why even put this up unless you actually did it and now getting flamed and want to take it back.
seriously dude, why even post this
Old Aug 8, 2011 | 08:22 AM
HMAX08's Avatar
edit did you pust up a post that you have a sticky caliper as well the other day. Here it is http://forums.maxima.org/6th-generat...y-caliper.html.
I am really starting to think you actually did do the powerwashing thing
Old Aug 8, 2011 | 08:23 AM
95Maxed's Avatar
Hahah, someone find that thread! Its the proof we need!
Old Aug 8, 2011 | 09:05 AM
RAZ76's Avatar
Nice Edit, you realized that you made idiot of the year and decided to act as if it was a joke, good one.
Old Aug 8, 2011 | 09:13 AM
aackshun's Avatar
Originally Posted by Mr. Blue Sky
^^^+1
Tooo late... Already on my other forums
Old Aug 8, 2011 | 09:14 AM
95Maxed's Avatar
Old Aug 8, 2011 | 09:16 AM
RAZ76's Avatar
Yup, I made sure to spread the retardness around, your welcome OIP.
Old Aug 8, 2011 | 10:05 AM
this was one hell of a lame joke it wasn't even funny just a waste of time...
when it comes to entertainment twentyeggs has the corner market
Old Aug 8, 2011 | 10:14 AM
HMAX08's Avatar
+1, agreed
HMAX08's Avatar
click, on the link in my post "sticky caliper" it would be underlined,
Old Aug 8, 2011 | 11:11 AM
ILL-Maxima's Avatar
wwwoooowww.... just saw this from the other forum... dude... why?? if you're not sure about something just ask here on the forums before you ask the sheepherder down the block!! smh... talk about epic fail!!!
Old Aug 8, 2011 | 11:40 AM
wirelessdude04's Avatar
I do this all the time.. Havnt had a problem yet? Did you use lots of soap? Maybe the foam is stuck in the bleeder
Old Aug 8, 2011 | 12:01 PM
Waxima's Avatar
Hahahahahahaha awesome.
Old Aug 8, 2011 | 12:03 PM
tibal's Avatar
hahahahahahhaha!!!
Riot!!
Old Aug 8, 2011 | 12:29 PM
MAXXED_816's Avatar
Old Aug 8, 2011 | 01:08 PM
Jerzey's Avatar
He def wasn't joking when he made this post.
Now he's playing it off as one lol
Old Aug 8, 2011 | 02:19 PM
95Maxed's Avatar
So did someone post this on my6thgen and nycmaximas yet?
Old Aug 8, 2011 | 03:22 PM
Kryogen's Avatar
It was obviously a joke guys. Get over it. I dont write that bad of a slang on the forums.
I know it's the best joke of the year though. Laughed my *** off writing it.
For those who wonder btw, I still didnt fix my sticky caliper. Ordered rebuild parts and they're in the mail. I wont know what was the issue until I rebuild. I did the rears last weekend, went fine. Just waiting on the parts for the front. I'll tell you what was wrong. I guess some rust/deposits on the piston jamming near the seal, or the hose has internally collapsed.
I'll post that in my original thread when I get to rebuild them in 1-2 weeks depending when I get the parts.
Old Aug 8, 2011 | 03:40 PM
95Maxed's Avatar
IDK if theres any coming back from this one. Joke or not
Old Aug 8, 2011 | 04:02 PM
BadBlackMaxSL's Avatar
You guys couldn't tell it was a goof just by reading the title? Although Kryogen may rub some of you the wrong way he never writes this poorly, he has a better grasp of the English language than that. C'mon guys, you're better than this.
Old Aug 8, 2011 | 04:21 PM
HMAX08's Avatar
^^^^ boy we sure hope so
