Help with radiator fan
Old Nov 26, 2011 | 07:48 PM
ilanpro's Avatar
Today I got home and the radiator fan on the driver side will not shut off even after turning the car off. Any ideas?
Old Nov 26, 2011 | 09:12 PM
timpol's Avatar
Is it turning off eventually? How long? Fans can run under normal conditions several minutes after the vehicle is off.
Old Nov 27, 2011 | 06:24 AM
ilanpro's Avatar
I went out this morning and plugged it in still running do the fans always have 12v to them even with the ignition off?
Old Nov 27, 2011 | 07:00 AM
ilanpro's Avatar
Fixed, Found the relay and tapped it twice to release, now it works like a champ. I will be replacing the relay tomorrow just in case it decides to get stuck again. thanks for the input everyone.
Old Nov 27, 2011 | 07:10 AM
timpol's Avatar
Nice. Was just going to add here that you should probably check the relays and replace it (them). Sounds like you have a faulty switch and it's a cheap fix.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
RWCreative
Sep 21, 2015 11:01 AM
