CLUNK- rear suspension
Old Dec 13, 2011 | 10:32 AM
acercomp71's Avatar
Does anybody have an idea what could cause slight clunking noise IN THE BACK when going over bumps?
Stabilizer bar bushings/links are out of question- replaced them recently, clunk is still there.
Exhaust mounts are out of question as well- everything is nice and tight.
Bad balljoint maybe? This model (2004) has control arms in the rear and bunch of bushings, trailer arms and whatnot.
Old Dec 13, 2011 | 11:53 AM
Excalibur23's Avatar
Its probably worn or blown shocks
Old Dec 13, 2011 | 12:15 PM
acercomp71's Avatar
nope..rear shocks are new
Old Dec 13, 2011 | 12:29 PM
oooo, how about the shock mounts? If the are new, is the rubber bushing already worn? No sure if a bent control arm will cause clunking....
Old Dec 14, 2011 | 06:31 AM
KRRZ350's Avatar
Clean out trunk, make sure jack is tight. Lift up rear and use prybars underneath tire & on suspension components to find what's loose.
Old Dec 15, 2011 | 02:20 PM
acercomp71's Avatar
i did that, clunk is coming from suspension for sure. Did check everything with a pry bar, nothing's loose, no play. Problem can be only under load though and while vehicle is moving. Did anybody ever use chassis ears?
matts95max
Apr 23, 2025 10:44 AM
doctorpullit
Sep 10, 2015 06:33 PM
ef9
Sep 5, 2015 11:18 PM
A32goldylocks
Sep 2, 2015 06:39 AM
