04 max with p0550 and p1284
Had a weird ticking noise during acceleration for a few days. Couldn't locate the noise and after a few days it just went away Started up the max today and got the two codes. The 0550 is the high pressure steering switch. Should be pretty easy to replace right? What my issue is with the other code. The 1284 code is a/f sensor bank 2. Correct? What the heck is an a/f sensor? I have replaced both o2 sensors within the last year if that matters. I'm just not sure what this is since I have never heard of an a/f sensor.
Ok
Well I had replaced both of the upper what I thought were o2 sensors. I did replace them with the Bosch universals. Think it may have gone bad? anyway to check them before I buy a new one? Also can someone let me know where the steering pressure switch is? Or even part numbers for both?
http://www.nissanpartsasap.com/nissa...&illust_seq=01
It should be located behind the right front wheel, down below the atf reservoir.
For the A/F ratio sensor see
Costee,
yes it is the power steering pressure sensor. On my scanner it says switch. apologies. Thanks for the diagrams. I'll check it out today. On a side note, anyone know how to remove the emergency brake handle? The nut that adjusts the brake stripped and I need to replace it. The nut is currently off. Do I need to take apart the whole center console??
litch
123
01-04-2024 07:01 PM
04-16-2020 05:15 AM
magiconthetire
10-26-2015 09:03 PM
