Twins or singles
Old Jan 25, 2012 | 02:19 AM
kurt1's Avatar
Twins or singles
Hay all
Our 6gens have twin mufflers at the rear. I know twins look good. But im thinking about doing a single muffler setup at the rear. Has anyone done this before a single setup.? Are the twins there for a reason as in for backpressure will i loose power going a single setup?
Cheers Kurt
Old Jan 25, 2012 | 05:35 AM
RAZ76's Avatar
I've seen it on one car and it made the Maxima look like a 4 banging POS. If you like it, do it. I don't, it takes away from the rear I think.
Old Jan 25, 2012 | 05:38 AM
the macedonian's Avatar
Originally Posted by kurt1
Hay all
Cheers Kurt
See below on the single setup ->
http://www.youtube.com/watch?v=QE9e-GkJI8g
See below for dual setup ->
http://www.youtube.com/watch?v=-UUSoe0N7Cc
Both are Vibrant Performance options. I listed those since after tons of research I decided it was the best sound IMO - hope this helps buddy
Old Jan 25, 2012 | 06:02 AM
BadBlackMaxSL's Avatar
Deus has a single black Vibrant muffler on the back. The vid above shows his setup. You can see he modded his bumper to eliminate the drivers side exhaust cut out. PM him and he can answer your questions.
Old Jan 25, 2012 | 06:48 AM
maximusberg's Avatar
I believe krazy6 also runs a single exhaust set up
Old Jan 25, 2012 | 09:32 AM
twentyeggs's Avatar
why would anyone eliminate a double exhaust setup??
it looks horrible!!
Old Jan 25, 2012 | 10:54 AM
T_Behr904's Avatar
I like the single exhaust setup in this vid because of that reason. It would look ghetto as fawk if it wasn't that way. I've seen so many cars with single exit exhaust that used to have duals, and it looks so cheap and ghetto. S2000's around here are notorious of looking like this.
Old Jan 25, 2012 | 11:04 AM
RAZ76's Avatar
it looks horrible!!
For once I agree with you 100%
Old Jan 25, 2012 | 11:13 AM
schmellyfart's Avatar
Single 3"
Old Jan 25, 2012 | 11:19 AM
NmexMAX's Avatar
dot dot dot ...
Single 3"
Is also what the fastest NA 6th gen has. Cool if that's what you're into.
My car is a 4 popping POS.
IMO:
For functionality, single 3".
For the look, duals.
Old Jan 25, 2012 | 11:26 AM
taz394's Avatar
i was gonna go with a single but it just doesn't look right ... i stayed with twin
Old Jan 25, 2012 | 11:35 AM
NmexMAX's Avatar
dot dot dot ...
Put a dummy tip A drone if you will.
Old Jan 25, 2012 | 02:46 PM
Akiriyama's Avatar
Originally Posted by NmexMAX
IMO:
This. Single also shaves off some weight so if you're about pure performance then go single. Personally I don't like the look of singles on a 6th gen maybe because I'm used to the dual, or because it would look too much like an Altima, or because I've seen it on Z's and G's and it looks off.
Old Jan 25, 2012 | 03:16 PM
twentyeggs's Avatar
LOL!!
Old Jan 25, 2012 | 04:12 PM
CRBWS6's Avatar
I first saw this on F-bodies in the 90's then on 350s last decade. We always want what we don't have....I wish I had duals on my 5.5
Old Jan 25, 2012 | 05:41 PM
mrjasonlyrics's Avatar
Why would you go pay to make it a single? I mean if it's just something you detach to make a single then yeah,but to have one would just costly
Old Jan 25, 2012 | 07:42 PM
Rods03Max619's Avatar
I think he has a CATTMAN on there...
Old Jan 25, 2012 | 07:51 PM
ShocknAwe's Avatar
I think people dont like it because your so used to seeing it a certain way. I think my 4th would look terrible with duals but then again I might get used to it after awhile. A dual down to a single just doesnt seem right. If you dont like the look of duals then go single, certainly your choice
Old Jan 25, 2012 | 07:55 PM
I don't remember everything, just ask my wife, but I do remember some random things and this is one of them.
http://forums.maxima.org/6th-generat...installed.html
Old Jan 25, 2012 | 08:09 PM
Nice Vibrants=Winning with the 6ths...
Old Jan 25, 2012 | 09:13 PM
T_Behr904's Avatar
Damn that thread got locked...
Old Jan 25, 2012 | 10:26 PM
kurt1's Avatar
Yeh I reckon fixing the second cut out it will look good and you'll get used to it. I prefer single for a few reasons like better flow. Don't mind the look of it. Less pipes-muffler. Only thing I won't to make shore if I go single setup will this affect performance? Only because it was a double standard. Could it possibly be a gain in performance because it's not going through 2 pipes?
Old Jan 25, 2012 | 10:29 PM
infinimax96's Avatar
I think with the right muffler, a single would look just fine. I like bigger single muffler tips, 3.5-4inch I think if you went with a small 2.5 inch for a single it would look silly.
Old Jan 25, 2012 | 11:28 PM
DeusExMaxima's Avatar
I like single because it flows better. I also like the cleaner look. I never really like 4 pipes sticking out the back but its just my opinion. A single muffler also weighs less, as pointed out earlier and sounds better since you dont have two competing sounds coming out two mufflers. I had a custom mandrel bent 3 inch pipe leading to a Vibrant muffler with two 14 inch magnaflow pre silencers installed on my car.
Check out my threads on this topic:
http://forums.maxima.org/6th-generat...ad-closed.html
Old Mar 24, 2012 | 02:32 PM
BRUISER's Avatar
One of the selling points for me on my '04 was the twin tip exhaust. I recently put a cat-back system on it, so it now has two 4in tips. I prefer the 4 tip config, so will change later, but the sound of a dual exhaust over single is "heart-rendering". Stick w/ the duals.
Old Mar 24, 2012 | 08:04 PM
6.5affiliate's Avatar
Keep it the way it is and possibly change out the mufflers. If you want a better look.
That is all.....
matts95max
Apr 23, 2025 10:44 AM
DJLAX152
May 4, 2021 11:46 AM
spazma7ik
Jan 12, 2017 09:38 PM
Max139617
Sep 29, 2015 06:44 PM
